CJD
Oh...you will probably want to plan your head too. The TR2 came with a "low port" head, where the intake runners do not rise above the top of the valve cover mounting pad. It is rare...so if you have one, keep it or sell it! Do not just let it go into the trash. Most of the low port heads were replaced long ago for the high port design, which is has better performance (at high RPM). The TR2 head takes H4 carbs, while the high port takes the larger H6's. On the street, both heads "feel" the same, as the TR2 optimizes the normal driving range as well as the TR3 head. Of course, the TR3 head produces more power, if you drive wide open throttle.
