Lubricating Leaf Springs
If I were going to the trouble of removing and disassembling the leaf springs I'd trim pieces of either the zinc or teflon sheets referred to earlier in this string rather than paint or lube them.
In the early years they made leather gaitors to cover the leaf springs and there were Zerk fittings on each end to fill the gaitor with grease. The gaitor kept the grease on the springs and not on the ground. Have not researched lately to see if they are still available.
Accents unlimited still makes them. Custom fit.
Has anybody tried the leaf spring liners? Cut to fit. They might add a bit of height also.
Looks like my garage door seal.
Has anybody tried the leaf spring liners? Cut to fit. They might add a bit of height also. View attachment 86495
I've installed them. The car is undergoing full restoration and it's not on the street yet. Write up was in November 2022 HM.
There are other liners that don't have such a large edge on them. I think they would look a little better on the finished spring.
