TR6 TR250 TR6 Rear Springs
glemon
I have three sets of rear springs for my TR250. Everything I read said the rear springs are too soft and you should upgrage, so I bought some heavy duty rear springs on E-bay of unknown origin. Then a read more and read that some heavy duty springs are too heavy duty. I am sure that is what I got.
So....I got the Moss heavy duty springs, these are supposed to be 20% stiffer than stock, when I got them I measured and they are between the stock springs and the heavy heavy duty ones in diameter. So far so good.
But it seems like a lot of people are selling their heavy duty springs on E-bay and going back to stock. So anyone have the voice of experience, should I fit the stock or the 20% stiffer?
The car is intended to be an all arounder, touring, zipping around town, occasional autocross. I want it to handle like a sports car, but don't want it to ride like a 3 ton truck without a load, I know I can experiment, but I would rather get the ones I like on the first.....er 2nd time, I also have a rear tube shock conversion (fitted) and front and rear ant-roll bars (not yet fitted). One thought is the stock springs and anti-roll bar may get me the closest to what I want.
P.S. the car is not yet on the road, so I can't just fit a pair and see what I like, if that is what you were thinking of writing.
P.P.S. The super heavy duty are marrked with two white and one yellow paint markings, the Moss heavy duty are marked red green red.
DougF
My spare set of "competition" springs are not on the car because of the ride height they gave. There was a huge gap from the bottom of the wheel arch to the top of the tire, especially with my 205/60-15. The car almost looked like a 4x4 conversion.
Mine were purchased in the early '90s from TRF.
poolboy
I was real happy with these. They are 1" shorter but settle less thereby making the ride height just fine. You may consider the 1/2" spacers, but I didn't need them. https://goodparts.com/shop/index.php?productID=280
Here's a picture of the car with the springs and the new owner.
HerronScott
Doug,
I bought TRF's SAH1081 for my TR4A back in 1982 and they were listed as "competition rear springs" at the time. I was pretty happy with the end result comparing front and rear ride height. You just used the rubber packing right?
Poolboy's picture look really nice and are probably more relevant though to what's being supplied today. Looks like TRF is selling these as well in case you can get them during a sale.
The Roadster Factory TR6 suspension page
COMPETITION SPRING KITS,by Richard Good at Good Parts
HG6 HP132 Competition Spring Kit;
includes a matched set of front and rear road springs,
lowers ride height by approx. one inch and provides a 20% increase in spring rate;
comes with a set of urethane spring packings
Scott
DougF
Yes, I did use the rubber packing. I didn't notice the gap as much when I had them on my old car.
I bought Richard Good's springs when I restored my current car and have been very happy with them.
cheseroo
slightly off topic but in the boxes of stuff I got with these cars I just bought was a new set of springs. I'm trying to figure out if they are stock, lowered or what. 1 set is 11 1/2" with a 3 13/16 diameter. The other 2 are 10 1/4" with a 4" diameter. Any ideas?
glemon
glemon
Rich, my stock rears are about 11" 3 13/16" diameter and the have a half inch round coil. Which means they are either later TR6 that have sagged a little or TR4a long springs, so I am now confused about my "stock" as in came with the car, springs as well.
The moss heavy duty rears are about 11 1/4" same diameter, 9/16" coil.
The super heavy duty are about 10 1/2" with a 37/64" coil
The Moss fronts are about 9 1/2 long and 4" diameter.
rjc157
i bought the ones from moss and the car sits way to high looks stupid now i have to spend another 200 to get a lower sports car look
sail
I have not fitted the springs I bought from TRF but measured, rears look to be
same as Scott has:
SAH 1081 11 3/4", .535 coil, 3 13/16" dia., marked with red and green dabs of paint. Says uprated 1968-1972 made in USA on sticker.
Front:
SAH 606 10 1/8", .541 coil, 4" dia., slightly thicker due to rubber coating that the rears don't have.
Says comp. grade made in USA on sticker.
Phone conversation with TRF told me stock height, 20% stiffer.
poolboy
20% stiffer but stock height may sit the car up higher as they may not compress as much as original weight springs when all is said and done.. At least that was my experience.
sunbeam25
wow I got the goodparts 470lb for rear. removed old springs to replace. only have had the car for a year so do not know the history. looks like some one cut the old springs and added 1" spacer. strange but the height on the old cut springs and spacer were same as goodparts so installed. man those are stiff. no way they will work unless I want to raise front end and go 4 wheelin. at least a 6" gap maybe more no reason to even measure. when trying to compress with jack under trailing arm I could only get axle perpendicular then the jack would lift the car
Got_All_4
glemon, I got Richard Goods springs for my TR250 and can't be happier. I use mine like yours for around town, fun drives and the occasional auto cross. Never thought they were too stiff for the road over 25k miles. Perfect ride height. Many of the heavy duty springs out there give too high of a ride height and looks terrible. I did use one 1/4" spacer on the front because I was uncomfortable with how close the front tire was to the fender. Experts thought it was ok but my concerns have vanished.
glemon
glemon
Thanks, 10 year old thread, I still have the car, still have the stock springs. Spacers under the front pans and I think the rears have sagged so car is lowered a bit too. I am happy with the handling and ride, the sway bars make a huge difference.
Got_All_4
A lot of the new springs out there ruin the ride height and handling of these cars. Some look silly too.
I'm rebuilding a 1969 TR6 and plain on using the original springs. Would love to do Richard Goods but trying to keep cost down plus I've never driven a TR6 with factory springs.
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
KVH General TR Best Year for TR6; Preferred over TR250? Triumph 11
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
JodyFKerr TR6 TR250 / TR6 Parts catalogs Triumph 1
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
K TR6 TR250/4 top on a TR6? Triumph 11
glemon TR6 obscure tr250 tr6 seat rail question Triumph 4
glemon TR6 TR250 TR6 no oil pressure after rebuild Triumph 20
KVH TR6 TR4A/TR250/TR6 Triumph 5
TR6oldtimer TR6 TR250-TR6 flywheels Triumph 6
T TR6 TR4/TR5/TR6/TR250 parts still available Triumph 4
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
heliguy TR6 TR250/TR6 shifter assy Triumph 2
jjbunn TR6 TR250 Ignition Switch in my TR6 Triumph 13
C TR6 TR6, TR250/5 Frame Dimensions...Who has them? Triumph 3
T TR6 TR250 engine or TR6 ? Triumph 8
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
