livinginthepast
...but I can't believe the differences from book to book on how a canister filter assembly should be setup with respect to the various rubber O rings, felt seals, etc.
When I pulled mine apart (61 948 BE) for the first oil change since I purchased the car last summer, I found nothing except a paper filter, spring and a pressure plate that sits on top of the spring inside the canister.
My VicBrit catalog shows inside the canister a steel washer, a felt washer and a circlip in addition to the spring and the pressure plate, although they call it a "paper filter" pressure plate (which implies that there is a felt filter pressure plate or none at all for felt filters??)
On the external side, some books show that a seal should set between the head of the center bolt and the canister, some show this as felt, some as a rubber O ring. Some add a steel washer to this mix (well, not for the purolater version, which has the 'collar').
My filter setup has the canister with the 'lip' at the bottom point of the canister. There was no collar, nor was there a washer or seal between the head of the center bolt and the canister housing.
Will someone please tell me what the optimal setup would be for this filter assembly so that I can hopefully stop some of the oil hemorrhaging from this part of the motor? I wondered why my car leaked like heck from the canister. I guess I know why now.
Thanks!
BillW
Thanks!
BillW
