inlet manifold
Don Jarr
Member
Hi
I’ve posted this in all the forums regardless of the car, as I’m hoping someone somewhere may have tucked away in their shed or garage, an inlet manifold to couple a Weber 48ida carburettor to an A-series engine, (for a Mini) Or you know of someone who might have one. These are incredibly hard to get hold of, and when they do come up for sale, it’s with a carburettor as well. I only need the inlet manifold though.
I’ve tried all the mini shops I know, and just about every other car spares shop, and still no luck.
Thanks for taking the time to read this
Don
C LCB header with 1500 single carb inlet manifold Spridgets 1
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
B AH Spares Ltd. Inlet Manifold No. FUL 340 Austin Healey 2
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
B TR2/3/3A TR3A VS TR4 Long Tube inlet manifold Triumph 8
M TR2/3/3A can you identify my inlet manifold? Triumph 3
E TR4/4A 63 TR4 Inlet Manifold question Triumph 4
F Problem fitting rear drain tube to inlet manifold on BT7 Austin Healey 4
M Inlet Manifold Question Austin Healey 7
J TR4/4A TR4 Upgraded inlet manifold/valve cover question Triumph 42
T Rawles inlet manifold Austin Healey 7
H HS4 to HIF inlet manifold question MG 2
AUSMHLY Inlet Manifold is dripping Austin Healey 2
D inlet manifold Triumph 0
D inlet manifold Sunbeam (Rootes) 0
D inlet manifold Spridgets 2
D inlet manifold MG 0
D inlet manifold Lotus 1
D inlet manifold Jaguar 4
D inlet manifold Austin Healey 1
D inlet manifold British Motor Corp 5
J gas leaking from inlet manifold Austin Healey 12
K TR2/3/3A TR3 gas tank inlet size? Triumph 2
T Muffler inlet/outlet pipe diameters [?] Austin Healey 3
C stuck inlet valve Austin Healey 7
58Custom 1969 Heater air inlet behind grill- pix? Spridgets 37
Tinkerman Mystery Inlet Valve Question Triumph 3
E HS4 SU carb inlet diameter? MG 15
G TR6 TR6 inlet valve dimensions Triumph 4
jerrybny Heater Inlet Hose Question Triumph 1
R Fuel runs outta carb inlet MG 22
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 9
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Carlbanan56 MGB Manifold plug MG 5
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
V MGB Replace late intake manifold angled breather with early model straight? MG 1
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
