BJ8 NGK Spark Plugs
AUSMHLY
I believe most people choose Champion RN12YC or NGK BP6ES.
I'm running Pertronix carbon wires, Pertronix ignitor, top load cap, Lucas sports coil.
Currently using RN12YC gapped .032. (Those who have the same setup as I, do you gap at .025, .030, .035 ?)
I'm thinking of trying the NGK BP6ES plugs.
When doing a quick search, it seems there are two version of BP6ES...7333 and 4007. Which one should I run, and what's the difference?
Also, what should I gap the NGK plugs?
As always,
Thank you in advance.
jimmyr
Re: BJ8 NGK spark plug
I believe the different part numbers on NGK's refer to a single plug or pack of 4 plugs. I have found that the BP6ES work very well and have good quality control.
LarryK
I used NGK in my GT6 and the shop I worked for used NGK. My main plugs are Champion, cheap and regular 2 yr warranty. The Champions are not a plug you can clean and reuse after flooding or after firing up rotted fuel. NGKs are better. Autolite can be cleaned and reused with regular use.
mgtf328
Probably a rookie question but why use anything other than the plug quoted in the Haynes manual - UN12Y gapped at 0.25? Also why can't you clean and re-use the UN12Y?
I do realise that Petronix recommend increasing the gap but can't remember by how much.
AJ
The only Champion I've seen in The Colonies is the RN12YC; the 'C' is for copper electrode, presumably to distinguish it from the exotic metal type prevalent today, and the 'R' is for resistor (about 15KOhms by my DVM). I've used them for years with nary an issue.
I used to try to clean plugs--even bought one of the pneumatic/media tools--but heard somewhere that media blasting can remove the glaze on the ceramic insulator, possibly causing misfire. I don't know if this is an issue or even a thing, but for the price of plugs if you're going to remove them why not put in new? Plugs can easily go over 25K miles in a properly tuned engine.
There are counterfeit plugs going around (notably on eBay): http://www.ngk-sparkplugs.jp/english/techinfo/fake/index.html
Note the 12YC cross-references to a BP5ES: https://www.sparkplug-crossreference.com/convert/CHAMP_PN/UN12Y
The NGKs will clean themselves if they get fouled, like getting loaded up in stop-n-go traffic. After an Italian tune up, they fire as crisp as they ever did.
Not so with Champions, I quit using them decades ago.
Apparently this is still the case, as a complimentary Champion* bit the dust in my 2-stroke McCulloch go kart engine. As soon as I replaced it with my preferred NGK, the engine fired right off!
* Champion plug provided to me by a fellow vintage karter at an event last year; carrying more spares now (will be interesting to see if I need them ;) )
Rob Glasgow
Perhaps we should install NGK plugs in our brains since they "self clean" when fouled. My brain seems fouled a lot lately.
AUSMHLY
AUSMHLY
Anyone recommend using the NGK BPR6ES (7131) resistor version over the the non resistor NGK BP6ES (4007, 7333)?
Example, I needed to run carbon spark plug wires because when I switched to negative ground my Smith electronic tach didn't work correctly with copper wire.
I'm currently using Champion RN13YC, problem free. Thought I'd try the NGK out. Resistor or not?
[h=1][/h]
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
