Wanted ISO: Main Link to mounting bracket screw
RJCOX
I am restoring a top frame (convertible top frame) for my 60 TR3 and I am missing one screw. Moss carries them, but I thought that I would try here first.
The screw is the Main Link screw that holds the top frame to the mounting bracket and allows the top frame to pivot/rotate on the mount. It is short but the head is big (wide, almost an inch).
If you have an extra that you are willing to part with, drop me a line.
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
R TR2/3/3A ISO ; One of these Triumph 14
B ISO two[2] steel road wheels, Morgan Other British Cars 0
Geo Hahn TR4/4A Iso ct 37854 lo Triumph 0
Editor_Reid TR5/TR250 ISO LBC Repair Shops in/near Atlanta Triumph 7
T SU looking carb with ISO stamped on the body Triumph 2
T SU looking carbs with ISO stamped on them? Triumph 2
Geo Hahn TR4/4A ISO 64 TR4 Owner with a Heritage Cert Triumph 1
S Wedge ISO Aftermarket & Upgaded Parts 4 TR8 Rebuild Triumph 9
soren_ak ISO Basil Austin Healey 1
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
J General TR Main bearing caps Triumph 6
D TR2/3/3A Main ground connection Triumph 2
R Main Bearing Cap Removal Austin Healey 12
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
S TR2/3/3A front main cap sticks proud Triumph 6
sim HUS 2 main jet adjustment Spridgets 40
C TR4/4A Rear main seal Triumph 36
