TR6 Steering column rubbler coupler
John_Mc
I'm replacing the old rubber coupler on the steering column. For the life of me, I can't get the screw holes in the rubber to line up with the metal bracket on the column! The width between the holes on the rubber seems to be a good 3-5 mm wider that the width between the holes on the bracket. Is there something I'm missing? Is there a special technique? Bentley makes it sound simple, but simple it is not. I'd appreciate any secrets to getting this back on. FYI, i have the earlier coupler that uses the two recessed allen bolts and two hex head bolts. It's the hex head bolts that are troubling me.
Gliderman8
Try putting a C-clamp on the rubber coupling to compress to get the holes to align.
TR250Guy
Agree with trrdster2000. If you cant find a hose clamp large enough hook several smaller ones together. Its what I used and worked like a charm.
KVH
Go to Home Depot, Lowes or HF and get a few of those slide clamps with the handle grip tightner. WOW does that make the job easy, and the clamping surface is insulated with hard plastic or rubber, providing a good grip.
poolboy
It also helps if both the steering column flanges on either side of the coupling are in the same plane, squared up to one another.
The rack may need rotating a tad to accomplish this...Not only does it make installing the coupling a bit easier, it also takes considerable stress off the coupling. Otherwise the coupling tries to act like the U-joint as you make turns and that contributes to the splits in the rubber coupling.
John_Mc
John_Mc
I used the C-clamp with good success. Thanks, everyone, for the input. Poolboy, you mentioned having the flanges in the same plane or else the coupler acts as a u-joint. Is this not part of the function of the coupler? Mine didn't seem to orient in exactly the same plane due to the higher angle that the column comes in at from the steering wheel.
poolboy
There is a real U-joint; but as you know, John, it's between the lower column and the pinion shaft.
The alignment is made at the rack, by rotation in whatever direction that creates the alignment.
Your rubber coupling will accommodate a certain amount of misalignment but it does stress it and contributes to the splits developing in the rubber.
Popeye
Bronze
KVH said it... the Irwin sliding clamps are the ticket. (If you don't have them, use this excuse to buy a set. They get a lot of use; the type of tool that I did not know how much I needed until I bought my first set. Now I have maybe 6 or 8 of them!)
https://www.irwin.com/tools/browse/clamps/one-handed-bar-clamps
(There are other brands... I'm not saying Irwin is the best, just what I happen to have.)
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
T TR2/3/3A Steering Column Grommet Triumph 4
D Ajustable Steering Column Escutcheon Austin Healey 2
6 Steering Column Spridgets 6
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
