John_Mc
I'm replacing the old rubber coupler on the steering column. For the life of me, I can't get the screw holes in the rubber to line up with the metal bracket on the column! The width between the holes on the rubber seems to be a good 3-5 mm wider that the width between the holes on the bracket. Is there something I'm missing? Is there a special technique? Bentley makes it sound simple, but simple it is not. I'd appreciate any secrets to getting this back on. FYI, i have the earlier coupler that uses the two recessed allen bolts and two hex head bolts. It's the hex head bolts that are troubling me.
