Healey 100 Overdrive stopped working
Walker sim
Hi,
The OD on my 100 has stopped working. I suspect a fuse but can't find it. Any clue as to where to start looking? The car is a BN1 with a BN2 gear box.
Thanks All, The problem is solved, someone had replaced the 50amp fuse with a 25amp. When I checked the fuse looked OK but the meter told a different story....Wally
roscoe
The link below is for a very good article and covers all the big Healey overdrive systems. Since the BN1 had a centrifugal switch that the BN2 does not have I can't be sure how yours is set up. Normally neither of them had a dedicated fuse and the OD was fused along with several other circuits on the same fuse at the A3 on the fuse block on the firewall. A common mod is to add an in line fuse that is specifically for the overdrive solenoid. You may or may not have one. There are multiple things that could be causing your overdrive to not operate. If it was the fuse at A3 other things would not work. It could simply be a broken wire or a bad solenoid. The cited article should help troubleshooting more than my guessing.
https://www.healey6.com/Technical/Tech-OverdriveTroubleshooting.pdf
Good hunting. Let us know.
Kainopong
Start with the solenoid itself - do you have a tester? If so, set it up for Ohms and set one clip on the wire from the solenoid and another to ground. It should read 5ohms or so. Then manually engage the OD (Push up the plunger) and you should see the solenoid jump to 12-14ohms. If not, bad solenoid and you should replace.
John Turney
Before you go digging into the overdrive to test the solenoid, test the dash switch. It's easier to get to.
roscoe
Buy extra fuses. You might need them if there is an unknown reason why it blew in the first place.
kurts100
The OD on my 100 stopped working 2 separate times. First time, as John said, my original dash switch finally bit the dust. The second time it was the switch on the side of tranny that is activated by gear shift lever in 2nd and 3rd gear. If that switch fails, current doesn't make it to solenoid.
Thanks Kurts100, the fuse, 50amps! (someone had changed with a 25amp), all good now.....Wally
Hope that's a slow blow fuse; like any inductive load--motors, solenoids, etc.--the OD solenoid is essentially a dead short for a couple milliseconds. Moss, I believe, sells the correct one.
Michael Oritt
My recollection is that the pull-in (intermittent) draw is 18 amps and the hold-in (continuous) draw is 2 amps, but I certainly agree with Bob that a slow-blow fuse is in order as you are essentially in a "locked rotor" situation.
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
R Healey 100 Dipstick Stuck Austin Healey 12
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
Guido36 Webers on a Healey 100 Austin Healey 6
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C What to do with my late father's Healey 100 Austin Healey 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
B Overcooling Healey 100 Austin Healey 13
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
dougie Austin-Healey 100 Documentary Austin Healey 3
H 100-6 Austin-Healey Austin Healey 7
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
Lin Spruce Green Healey 100 Austin Healey 17
G For Sale Healey 100 windscreens for sale Austin Healey Classifieds 2
N Healey 100/4 from the Bahamas Austin Healey 8
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
C For Sale Healey 100 for sale Austin Healey Classifieds 3
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
W Healey 100 dip stick Austin Healey 16
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P Wanted Austin Healey 100-4 Bulkheads Austin Healey Classifieds 2
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Austin Healey 100 engine color Austin Healey 10
S For Sale Austin Healey 100-4 Grille Austin Healey Classifieds 2
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
D Healey 100 issues Austin Healey 15
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
vette What is an Austin Healey 100-6 MM kit. Austin Healey 10
H Healey 100 Painting Austin Healey 5
W Austin Healey 100-6 Sell or Restore? Austin Healey 5
L For Sale Austin Healey 100 literature for sale Austin Healey Classifieds 1
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
