Wire Wheel Knock Offs - How Tight?
RJS
Just curious,
How tight is sufficient? Should I be hammering these on with all my might until the knock-off moves no more. Or, just knock them on until sufficiently snug?
I use a lead hammer and have the wooden knock off wrench from Moss.
Thanks
HerronScott
Bob,
When our cars were driveable and our daily drivers (TR4A and Spitfire), I always knocked them on until they didn't move using moderate blows. I was using the copper-faced regular sized Thor hammer so not enough force that I felt I was going to deform the knock-off.
Scott
SkinnedKnuckles
I always tighten until pretty snug - not un til they don't move. It's my understanding that they tighten more while driving.
TR4A_IRS
As a point of reference, the new Porsche GT3 with center lock wheels has a torque requirement of 365 foot pounds. I doubt if you want to go that high, but...
vivdownunder
The knockoff should be tightened to a point where the wire wheel isn't loose on the spline. Then lower the tyre just barely onto the floor to take the shock, rather than through the suspension, and finally tighten two-three more hits.
A double ended Thorex 716 engineer's hammer with 50mm replaceable nylon heads is the ideal tool to use, as it can't bruise the knockoffs.
Viv.
Twosheds
I fetch 'em a good lick.
rggav
Here is what Dayton says :
<a href="https://www.daytonwirewheels.com/pdf/installationinstructionsfork-o.pdf" rel="nofollow" target="_blank">Dayton
Wheels PDF</a>
Tinkerman
Thanks for the Dayton info RG. Put it in my tips file.
Tinkerman
TR3driver
Great Pumpkin - R.I.P
Wow, they want them really tight! I guess I've been leaving mine too loose all these years.
Thanks for the link!
Roger
Bronze
I know nothing about Dayton Wire Wheel adapters, for which those instructions were we written. Nor do I know about Porsche's recommendation, but I suspect that's for a peg drive, not the Rudge-type hubs on British cars.
Vivdownunder's post is right on. And yes, Rudge hubs in good shape with tapers in good order on wheels and caps will self-tighten.
prb51
I have been told overtightening on our style of wheels can eventually deform the wheel hub leading to quicker wear of the splines.
I give mine a few solid whacks but don't go ballistic and they stay tight.
I also suspect Daytons recomendations are driven primarally by concern over litigation of a lost wheel rather than proper technique to give the wheels longevity. Just a thought.
TR3driver
Could be, but I put all new Dayton wheels, adapters & knockoffs on the Stag and tightened the knockoffs just a few hits (Stags have safety knockoffs, so I used an original steel knockoff wrench and ~2 pound brass hammer). A year later, although the knockoffs were still quite tight, there was visible wear on the splines.
If I ever do get that car back on the road, I'm going to keep them tighter as per the Dayton instructions.
vivdownunder
One thing I beg to disagree with Dayton on is lubing the hub tapers. I leave them dry so they get a good friction grip once the knockoff it tightened.
Lubing the hub tapers makes it easier for them to slip back and forth with stop start driving, thus causing premature spline wear. Also by leaving them dry you don't have to belt the daylights out of the knockoff to get the wheel on tight.
The actual spline itself is all that needs a smear of grease.
When refitting a wire wheel I wipe some WD40 around the outer taper so the knockoff doesn't bind.
Over 40+ years of driving many wire wheeled cars over long distances, I've never replaced a set of worn splines.
Viv.
kodanja
ya gotta really tighten those BUGgers'
aeronca65t
I tighten the two-eared knockoff on my MGB <span style="font-style: italic">reasonably tight</span>, drive it a bit, give a couple of more slaps with a lead hammer, and then safety-wire one ear to a spoke.
I notice that some racers drill a tiny hole on the outer end of one ear to make this easier.
TR4 Wire Wheel Knock Offs???? Triumph 13
Todd78d Wire wheel cleaner Spridgets 1
K 1068 mkIII wire wheel rub Spridgets 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
P Wire Wheel Splines Austin Healey 10
RJS General TR Wire Wheel Spline Question Triumph 3
B TR4/4A Wire wheel question Triumph 10
P TR5/TR250 wire wheel question Triumph 3
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
M Chrome wire wheel questions Spridgets 5
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Wire Wheel Grommets Triumph 5
Raymond MGB Wire Wheel Tire Mounting MG 0
Raymond MGB Wire Wheel Cotter Pin MG 5
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
B General Tech Wire wheel sealing bands? MG 4
J For Sale Wire wheel set Triumph Classifieds 2
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
M TR2/3/3A Wire Wheel Splines Triumph 3
Zitch Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
S MGA wire wheel space saver spare MG 1
N Wire wheel hub removal & suspension tear down Spridgets 3
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
PAUL161 General MG Wire wheel balancing service MG 2
S General TR Wire Wheel New Tire Installation Question Triumph 11
GTP1960 TR2/3/3A Hub extension torques? [for wire wheel] Triumph 4
S TR2/3/3A Wire wheel balancing Triumph 16
M wire wheel spokes "tuning" Austin Healey 8
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
J General TR Wire wheel sale pricing Triumph 18
J How to repair a tubeless wire wheel leaker ? Austin Healey 10
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
K 1960'es Dunlop wire wheel paint colour code Restoration & Tools 0
K General Tech 1960'es Dunlop wire wheel pint colour code Triumph 13
5 Bugeye wire wheel dust caps Spridgets 4
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
P New England Wire Wheel Triumph 2
D new member with wire wheel questions Jaguar 6
D new member with wire wheel questions Austin Healey 7
