When I got my TR, the wipers worked fine, but didn't "auto park" when powered off. Just stopped dead when you cut the power at the dash switch.
I cleaned all exterior motor wiring connections, no change.
I removed the motor assembly, cleaned inside and out (found the copper "commutator" for the auto off was coated with thick hard grease).
Reinstalled the whole assembly, re-connected wiring, and still no change.
I also notice the wiring diagram (Advance) for the TR3A shows only two wires plus ground: a solid Black to terminal 1, a solid Green to terminal 2, and a Black to ground.
Mine has one Green with Black stripe wire on terminal 1, two Green wires (connected into one covered spade terminal) for terminal 2, and a smaller gauge Black to ground.
The panel switch has only On and Off. (single speed)
Could someone please check their TR3A DR2 motor wiring? I'm wondering if I just don't understand the Advance Wiring diagram, or perhaps my wiring is "creative". However, the wiring comes from the original fabric covering, and is quite old.
Any thoughts on why mine can't "auto park"?
Thanks.
Tom
Thanks.
Tom
