Windshield glass replacement
Ray Smith
I have a new glass for the "A". When I put the frame together, it appears that the screws that go throught he tapping plates on each side protrude past the plates approx. 1/8 to 3/16". I fear that if I install the glass the screws may break something.I am also having trouble getting the glass to go into the frame because there does not appear to be enough room for the weatherstrip and the glass to go into the frame. Any and all suggestions, tips, curse words, etc. will be greatly appreciated.
Ray
tony barnhill
Great Pumpkin - R.I.P
On my TD that just got new glass, the instructions with the nut/bolt kit said to test fit everything without the glass & cut the ends of the bolts so they barely protrude through the metal...when you do, use a nut so that after you cut them off, you can take the nut off the bolt, cleaning the threads
ronzet
Ray,
I just last week replaced the windsheild in my A... I bought the mounting hardware kit from MOSSS and all of the bolts, nuts, and washers fit perfectly...
However,
I bought the glazing strip from Moss recommended for the thinner windshield... It was too thick...
RECOMMENDATION -- for less than $100 a good Auto glass shop will do the deed for you. I gave mine to a shop that provided the correct glazing rubber and installed the frame around the windshield... All I did was pick it up, pretty as a picture and ready to mount, which I did.... /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
No muss, no fuss.... there are many other things on the car that I would rather spend my time on. Using the services of a shop that knows their business is, for me, a no brainer.. /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
ronzet
Ray,
I should mention that I fought with the installation for about 3 hours before I gave up and sent it out... one of the few things that was jobbed out on my A... /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
tony barnhill
I fought with my TD windshield build for about 7 hours including assmebly without glass, disassembly & reassembly....then, installation onto car took about half hour!
ronzet
Tony,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I fought with my TD windshield build for about 7 hours [/QUOTE]
You are a better man than I, Gunga Dinn..... /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Once I pickup up my windsheild and frame I installed it, like you, in 30 minutes... then on to other schtuff.. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Steve_S
If the screws stick out enough to put pressure on the glass when tight, you need to shorten them. Over time it will crack the glass. Remember that the corner brackets float around a bit by design, so you may have some fudge room on those.
There are two different glazing seals sold. You may simply have the wrong one.
O TR2/3/3A TR3 Windshield Glass Replacement Triumph 2
D TR2/3/3A Windshield glass doesn't fit Triumph 6
B Windshield glass, where to buy Restoration & Tools 4
C MGB 1966 MGB windshield glass MG 4
B MGA Windshield glass MG 11
KVH TR4/4A Removing Glass Windshield Triumph 4
Rob Glasgow Windshield glass Austin Healey 5
TR3TR6 TR6 Tr6 windshield glass removal Triumph 6
T TR2/3/3A TR3A windshield glass Triumph 13
6 TR2/3/3A TR3 windscreen/windshield glass Triumph 5
B Removal of 100-4 windshield glass Austin Healey 1
L Bugeye windshield glass installation Spridgets 13
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
PAUL161 Moss & New Windshield Glass ? UPDATE MG 5
PAUL161 Moss & New Windshield Glass ? MG 7
T bn2 windshield glass Austin Healey 1
A Windshield/Glass cleaning Restoration & Tools 0
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
M General MG Midget MK1 windshield replacement MG 2
R TR2/3/3A Fitting windshield Triumph 3
steveg Rebuilding roadster windshield Austin Healey 24
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
Z TR2/3/3A Windshield Aftermarket Triumph 22
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
D TR2/3/3A Windshield difficulties Triumph 24
Rut Cut down windshield Spridgets 22
R Windshield Washer Pump Repair Austin Healey 9
M BJ8 Windshield Austin Healey 10
