Removal of 100-4 windshield glass
BN2guy
Does anyone have a solution, or even an idea, as to how I might get the glass out of the frame of the windshield of a 100? The side pieces of the frame were no problem - just a few taps with a small hammer on a piece of wood placed against the frame and they came loose. However, the top and bottom channels are a different matter. I tried using liquid dish soap, and when that didn't work, a lot of WD-40, with several days soaking time, to soften the glazing rubber so that I could remove the top and bottom channels like I had done of the sides. But it didn't work. The glazing rubber will not let go of the glass. My objective is remove the frame for re-chroming. I was hoping to avoid using a large hammer, followed by a broom, and the purchase of new glass. I had thought about using gasoline, lacquer thinner, and similar liquids to soften the rubber, but I don't want to use something that will seep in at the edges and attack the plastic laminated into the safety glass. And, I'm afraid to use brute force for fear of breaking the glass. Does anyone have any thoughts as to what might do the job? I'll appreciate any help.
Been a while since we had our BN2's windshield apart and back together, but is it possible to get a screwdriver under the ends of the channels and pry the channels up from the ends? IIRC there's an angle bracket on the corners; if you can get that off maybe you can get a screwdriver started under there.
Could you work one of the wire 'garrottes' in there to cut away the rubber, like the pros do to replace a modern, glued-in windshield? How about something less exotic, like a razor blade? If you can sever the rubber on the sides of the channel I expect the rest would give way.
C Removal of windshield posts from my 100-6 Austin Healey 7
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
C removal of transmission cover from 1959 100-6 Austin Healey 16
R 100-4 dashboard removal help Austin Healey 4
R 100-4 front fender removal Austin Healey 2
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
Walter74 Adjustable steering wheel removal Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T BJ8 Drain Channel Removal Austin Healey 2
D TR2/3/3A Facia removal steps Triumph 3
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Spitfire Triumph spit flange/hub removal Triumph 13
