Window Regulator BJ7 vs BJ8
AUSMHLY
Is the window regulator in the bj7 and the bj8 exactly the same, interchangeable?
Patrick67BJ8
I beleive they are. Did you CAD plate yours?
Keoke
:savewave:
Yep:----
Frameman
No, the regulators are not the same. The shaft lengths, where the window crank goes, are different.
If you would like to call me tomorrow (905-854-3555), I can tell you exactly which is longer, I just don't have the information on me right now. But I believe the longer shaft is on the BJ8.
AUSMHLY
AUSMHLY
Thank you Frameman,
What is the length of the BJ7 and the BJ8 window winder shafts?
Why would the shafts have different lenghts?
I thought the only difference between the BJ7 vs BJ8 was the door panel.
The BJ7 having a small pocket area for maps.
Always good to ask questions.
RAC68
The door panel center, where the crank is mounted, is set IN the center opening on the BJ7 and set OUT on the BJ8.
Ray (64BJ8P1…still hear)
Patrick67BJ8
Thank you Frameman,
Here's photo of my BJ8 Window Crank unit with ruler for measurement of stem length.
Frameman
Hi,
Here are the lengths :
BJ7 Shaft is 1 1/2"
BJ8 Shaft is 2 1/2"
The BJ7 Shaft is not long enough to reach the BJ8 door panel.
The BJ7 door panel is recessed in the door hence the difference. The bracket for the window crank is closer to the outer door skin than the BJ8 making the clearance different. The longer shaft won't be able to clear it.
AUSMHLY
AUSMHLY
Here's photo of my BJ8 Window Crank unit with ruler for measurement of stem length. [/QUOTE]
Thanks Patrick. Is that a rubber O-ring? My stem does not having anything like that on it. Maybe that's why my gas mileage sucks.
AUSMHLY
AUSMHLY
Frameman said:
Hi,
BJ7 Shaft is 1 1/2"
BJ8 Shaft is 2 1/2"
Thank you Frameman for taking the time to measure those. I'm sure down the road when this topic comes up again, you'll be the one we thank...again.
Patrick67BJ8
Thanks Patrick. Is that a rubber O-ring? My stem does not having anything like that on it. Maybe that's why my gas mileage sucks. [/quote]Yes, it's an "O" ring. It's an old trick I learned from one of those old car magazine ad's claiming to increase milage.
I also increased my HP by 50% by changing the distributor mechanical advance springs too.
Keoke
--------------Keoke-- :lol:
AUSMHLY
AUSMHLY
Frameman said:
Hi,
BJ7 Shaft is 1 1/2"
BJ8 Shaft is 2 1/2"
Interesting. Patrick shows his BJ8 to be about 2"
Patrick, did that come off one of the mid year BJ7-BJ8 cars, being the shaft length is between 1 1/2" - 2 1/2" ?...lol
Patrick67BJ8
AUSMHLY said:
Seriously, am I missing the o-ring? What is it's purpose?
The O-ring makes a snug fit for the window crank and stem to keep them from rattling(like we really can tell a rattle in a Healey?). They really do work! Let me know of you need to know the correct size to buy?
Patrick67BJ8
AUSMHLY said:
Frameman said:
Hi,
BJ7 Shaft is 1 1/2"
BJ8 Shaft is 2 1/2"
I really think the measurement is where a person takes his measurement from. I did it the easy way because I didn't think you wanted to dismantle the unit to get the overall size. I hope where I took it from is good enough.
I think my car is midyear if you consider that new cars come out in the Fall and mine was built in March '67. VIN-40928
SpeedyG TR4/4A Door window regulator spring Triumph 5
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
B TR4/4A Window Regulator Leather Washers Triumph 6
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
waltesefalcon Window regulator Other Cars 1
M TR4/4A Another question on window regulator. Triumph 3
M TR4/4A Window regulator assistance please. Triumph 1
sundown TR6 window regulator Triumph 3
sundown TR6 1973 TR window regulator Triumph 2
2wrench TR6 Help installing door handles/window regulator handles. Triumph 9
D Don't ignore stiff window regulator Austin Healey 8
Tim Tucker TR4/4A TR4 STOP BRACKET for WINDOW REGULATOR Triumph 5
H TR4/4A Window Regulator 4a Triumph 0
E TR4/4A TR4 Window regulator Triumph 2
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
AUSMHLY Window Regulator repair Austin Healey 3
BubbleTop61 Window regulator interchagebility MG 6
H Lubrication of Window Regulator Hardware Other British Cars 3
3 TR6 TR6 window regulator channel. Triumph 8
S Window Regulator Compatibility MG 2
O Jaguar rear window trim repair Jaguar 1
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
Bayless How to repair broken vent window studs? Spridgets 1
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
algot1901 Window Channel Ford Prefect Other British Cars 5
DrEntropy Benz electric window battle Other Cars 13
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
Robert Somma power window installation TVR 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
HealeyRick BJ7 Side Window Alignment Austin Healey 31
nichola TR6 Door handle and window crank installation Triumph 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
P TR6 Tight window crank Triumph 9
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B TR4/4A Window Channels Triumph 6
JFS Wedge Door wing window finisher Triumph 2
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
A PLATE, handle locking on Vent Window Austin Healey 0
B Side window question for early Longbridge BN4 Austin Healey 4
T TR6 Frosted rear plastic window Triumph 6
G BJ7 Window channel position Austin Healey 1
P Rivets on windshield and vent window frame. Austin Healey 1
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
B BJ8 vent window collar fused on Austin Healey 7
M Zip-Out Rear Window on a BN-7 Top? Austin Healey 11
Zitch TR4/4A Window Guide Writeup Triumph 2
M window rattles Austin Healey 5
Scotsman TR4/4A Need FELT for window channel Triumph 8
