Wellthere's nothing for it... The body comes off!
TypeRboy
My clutch on the Elan is just not going to release. I rebled the system, but there was no air in it anyway. I adjusted the slave rod to the point where the clutch shouldn't even be engaged, then drove with the clutch pedal depressed trying to bunny hop the car and break the clutch free. Those darm metalastic joints absorb driveline shock so well that I can't get any real inpact to the clutch. Too much power and the wheels just spin, so the power on and off thing was a bust.
I'm missing a car show this week, and I don't know when I'll have time to work on the car now...The body will have to come off and the drivetrain out... could be an all summer project..
Makes me wonder why I bothered to put all new parts into the car when it does something like this... The clutch has only about 300 miles on it..
PC
Re: Wellthere's nothing for it... The body comes o
Had similar symptoms in a car once, appeared that the clutch wouldn't disengage no matter what. Turned out it wasn't the clutch at all. The pilot bearing had seized.
Don't know whether the PO had replaced the clutch and forgot to grease the bearing or the clutch was original and the factory grease had disappeared. Either way it was ground up into little bits and seriously stuck. I had to chisel it out.
When you pull the driveline make sure you either have a new pilot bearing in your hands or at least readily available from your favorite supplier.
PC.
/ubbthreads/images/graemlins/hammer.gif
coldplugs
Platinum
[ QUOTE ]
...The body will have to come off and the drivetrain out... could be an all summer project...
[/ QUOTE ]
The clutch on my Elan occasionally stuck after a few weeks of non-use but I was lucky at freeing it, I guess. You're right about the doughnuts absorbing shock you'd rather was sent on to the clutch.
Why do you need to take the body off? The engine and transmission will slip out the front, won't they?
TypeRboy
TypeRboy
Well you might get the motor out alright, but re-connecting the driveshaft into the back of the tranny would be impossible, as the the shaft is in a tunnel. I might be able to just remove the motor, but getting at the bolts would be a real task.
I had considered the pilot bushing seizing, but immediatly discounted it as then I might not be able to seperate the motor and transmission. I've decide that I want the clutch disc to be the problem, and I'm sure wishing will make it so! ( the pilot is the most likely, and the ugliest possibility..)
I had soaked the bearing in oil for a few days prior to putting it in, but didn't use any other lube on it. I thought they were supposed to be self lubricating, but I guess not.. /ubbthreads/images/graemlins/nonono.gif
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
J Nothing is ever easy! Austin Healey 12
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
T Post-War Other Nothing's easy Triumph 6
E General MG Besides falling in love with my new purchase - I know nothing about MG Midgets MG 7
S Nothing like a cloudburst... Spridgets 19
T Anything or nothing. Austin Healey 3
J Got my Heritage certificate but nothing new came on the sheet British Motor Corp 2
G HELP!!! We have suddenly have NOTHING to drive! MG 44
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
B Nothing to see here,pic attach attempt MG 7
2wrench Aint nothing happening on the rebuild Triumph 35
B Nothing mellow about this yellow Austin Healey 1
H Brakes done, nothing new there. Have a rocker ? Spridgets 5
G I don't trust nothing I can't see...electricity Triumph 4
G So I have nothing better to do Triumph 17
J TR4/4A TR4 won't start, won't turn over, nothing. Triumph 15
S Wedge TR7 1, Sam nothing Triumph 4
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
