Unusual Air Filters
angelfj1
I just couldn't resist posting this photo - from and Ebay TR3A for sale. Isn't that "chicken wire"? :jester:
Mickey Richaud
Yep, and I'll bet you dollars to donuts he doesn't have a problem with chickens gettin' sucked into the venturis!
PAUL161
<span style="font-size: 11pt">Or rocks!</span> Looks like they've been on there for some time. Hate to see what that engine looks like inside.
martx-5
Yes. Will the price come down on a group buy??
TR3driver
Great Pumpkin - R.I.P
poolboy
Really, that stuff is called "hardware cloth". No matter though, a chicken still can't get thru it.
PeterK
I really like these and just threw out the group buy idea without contacting the maker. But I would "assume" that like many items a group buy of 10 or more would be leverage to get a deal.
So keep posting yea or nay and if there's enough, I'll get in touch with the mfgr.
PeterK
Reading between the lines it looks that the CNC is setup to make 4 sets at a time so like-set orders are preferred. PM me if you are interested. I'm not in a rush for mine as the engine is still apart.
Here's his reply:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] First of all, thank you for your interest in our products!
As to a volume discount, that would depend on the order "make up" as the filters that fit on HS6 equipped TR4s are not the same as the filters that fit on H6 equipped TR3s. Some of the later model TR3s also will need to change/reroute the overflow pipes of the H6 carbs in order for the filters to fit properly. The TR4s can utilize the 2.6" filter length while most TR3s will need the 1.6" length due to inner fender issues. So many of these cars have had various modifications over the years it is hard to come up with any iron clad rules as to what will fit what.
All that being said, if you are interested in an order of 4 sets (the discount applies in multiples of 4 - i.e. 4,8,12,16 etc.) I can offer you a 10% discount on a trial order of 4 sets providing they are not TOO different. Also some additional lead time is necessary on such an order - for Triumphs I think something on the order of a "fortnight".
Shipping is another area that would offer a considerable savings if the entire shipment could go to a single US location. Otherwise shipping would be about the same as advertised as we ship at our cost.[/QUOTE]
M_Pied_Lourd
Looks like they are old gas mask filters...
Cheers,
M. Pied Lourd
tinman58
I would go for it for my TR3A! The air filters are a nice touch.
Vaark01
I would also like to join a group in getting a pair for my stock 1962 TR-3B with bigger engine (TCF 486L).
Keep me in mind.
Thanks.
Paul
TR4nut
Am I missing it on the website - do they do a Triumph logo? The Healey logo they did looks good.
Murray
Member
They do a Triumph logo.I bought one 2 months ago and it doesn't fit my TR3A. He forgot to offset and raise the carb openings. The opening for the carb is right in the center. He obviously never put one on a TR3, because it will not fit.
Murray
PeterK
That's odd he would have to offset opening. On my 3A, the K&Ns are centered and are 1-3/4" thick. Clearance on the inner fender is about 1/2".
What did he say about the fit problem?
Murray
Member
He just told me to return them. If your filters were centered there would not be any room for the fuel overflow tube.
Murray
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
roscoe An Unusual Healey Mission Austin Healey 2
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
T Unusual gearbox identification Spridgets 1
TomMull Somthing affordable and unusual for the car shows? Other Cars 1
Brinkerhoff TR4/4A Belgium built TR4A, is a bit unusual ! Triumph 16
Bob Claffie Spitfire Unusual parts Triumph 1
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
T TR2/3/3A Unusual Tires On TR3 Triumph 24
catfood Unusual BN1 Austin Healey 12
B General TR Unusual banjo pieces for brakes? Triumph 3
V TR2/3/3A Unusual Engine Number Triumph 5
angelfj1 TR2/3/3A TR2.5 - Unusual wheels and mirror Triumph 11
K Most Unusual Bodge or Repair by a PO? Triumph 21
DNK So that's unusual Lotus 6
angelfj1 TR2/3/3A A most unusual TR2! Triumph 17
angelfj1 Unusual TR Commission Numbers Triumph 7
G Something unusual at the station today Other British Cars 0
tony barnhill Unusual Things Found in Your Car MG 29
AngliaGT Unusual Sight Today..... MG 8
jlaird My unusual day. Spridgets 23
NutmegCT unusual starter noise Triumph 7
A Unusual 1963 Honda S600 Sports Car Other Cars 20
jlaird Unusual for me Spridgets 10
tony barnhill So, Where's the Most Unusual Place You've... MG 43
Sherlock Unusual automotive sightings Other Cars 2
Sherlock Unusual cars in movies - news flash Other Cars 3
Sherlock If a Mini isn't unusual enough for you... British Motor Corp 17
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
