turn signal lights with LEDs
Jerry
I replaced my turn signal bulbs with LEDs. They are much brighter but the flasher kept working intermitantly. I finally decided to order a flasher unit made for LEDs. It was the most inconsistant eletrical problem I have ever worked on. The lights acted like the ground was not working.
I will let you know how they work once the new flasher is installed.
Jerry
BJ8
AUSMHLY
Hello Jerry,
If the one you ordered doesn't work, try this electronic flasher from Napa. It stops led bleed over.
Drive it like you stole it.
Roger
GregW
Platinum
Yeah, you pretty much need a blinker relay designed for LEDs. LEDs just don't load the system enough. When I did my motorcycle, I tried the turn signals just for fun. Left turn was fine, right flashed at hyper speed.
Hedgehog
Is there a ready made LED option for the tail lights of the 100/4 BN1s? If so, could someone post a link or contact info.
Thanks.
Keoke
Check Hendrix Wire Wheel. The design baseline for these type lights can be found in the archives on this forum---Keoke
J
Jerry
I got the LED flasher installed. Works great but does not click or make any noise when it blinks.
I wonder if I will remember to turn it off?
Jerry
BJ8
AUSMHLY
Jerry
BJ8
Not to worry. Cars will pull up next to you and remind you.
In return you'll give the thumbs up and smile.
J
Jerry
I found a little buzzer that Lin Rosewood put on his car. Radioshack 273-059. Might buy one of those. I also noticed that both turn signal dash lights flash when you turn on the turn signal either way.
Apparently the combination of the LED lights and a regular flasher causes some kind of ground feedback that was affecting my gas gauge. Now that I have installed the LED flasher, the gauge works correctly again.
Mess with original, and you get more work!
Jerry
BJ8
Ed_K
Jerry,
If you install one of those electronic flashers like in Roger's
above post, then they both won't flash at the same time. I also had the same problem and fixed it with the same type of flasher that Roger has.
Ed
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
G MGB Turn signal, reverse and brake lights MG 9
rjc157 turn signal lights Austin Healey 8
J Turn signal dash indicator lights Austin Healey 20
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
O TR2/3/3A TR3 Turn Signal Lights Install Triumph 1
D T-Series turn Signal lights on MG TD MG 1
fmichaels 67 parking/turn signal lights Spridgets 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
