Turn signal dash indicator lights
Deleted member 19315
Vette, brilliant; problem solved ....the new relay was not working correctly exactly as you said. Many Thanks
KVH General TR Green Turn Signal Dash Indicator Triumph 8
A TR4/4A Turn signal dash light inop? Triumph 6
ooman Looking for dash turn signal indicator - '67 BJ8 Austin Healey 10
Jim_Gruber Need Light Bulb Socket / Turn Signal / Behind Dash Spridgets 1
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
