TR6 TR6 Won't Start Just Clicks
Gerry M
Some quick background (may or may not be relevant).
1. car has always started fine.
2. transmission and clutch were removed & replaced a short time before my starting problem.
3. afterwards the car continued to start fine initially but soon refused to start.
4. when ignition key is turned on I get a single click (sounds like it is coming from starter/solenoid not the relay.
Questions:
1. Could my starting problem be related in any way to the recent transmission/clutch work?
2. what is the likely cause and solution to my starting problem?
Thanks for any help/suggestions.
Gliderman8
Have you checked/charged your battery?
Do you have seatbelt interlock?
TR3driver
Great Pumpkin - R.I.P
Not likely to be related to the work IMO, except perhaps a connection wasn't tightened or something. You might check that the starter bolts are tight.
I'd try connecting a momentary jumper from the heavy battery cable to the terminal with the white/red wire at the starter solenoid. If that makes the engine crank, then there is a problem with the switch or wiring to the solenoid (and perhaps the seat belt module if you have a 74). If not, then a starter/solenoid problem, or perhaps lack of power from the battery (bad ground).
poolboy
Can you push the car even a foot forward when it's in 4th gear ?
I once had a starter hang up on the flywheel...that's the test. If it rolls in gear it's not hung.
Gerry M
Gerry M
Tried rolling it in gear. It doesn’t roll. How do I fix a hung up starter? What would cause the starter to hang up?
poolboy
Remove the starter; but you may have to pry it loose if it really is hung up on the flywheel's ring gear.
If it turns out not to have been hung, you probably would have wanted to remove it anyway to have it properly checked at a Starter and Alternator shop.
What makes a starter hang up ?
In a broad sense...an engagement problem...bad teeth, a weak starter.
The last one I had hang was in 1965 so I don't remember the details of the repair, just how it was diagnosed.
James Christie
If starter pinion and flywheel teeth really are jammed , before taking it all apart try putting in 3rd gear and the car rocking backwards and forwards. You'll hear it release. - if it does.
james
TR3TR6
It sounds like it is hung up, even if you get it freed up I would do as Poolboy recommended, pull the starter and have it checked out at a starter shop. If it hangs up once it will probably do it again. When they put a new clutch in I would hope they checked out the ring gear and replaced it if necessary. With the starter out, you might want to take a flashlight and see if you can see the teeth on the ring gear.
charleyf
Getting a starter out of a TR6 is no small thing. Do a thorough check for a bad connection or ground before diving into that chore. The battery can be fully charged but if the power is not getting to the starter it is meaningless.
Gerry M
Gerry M
If the starter is hung up and I try to bump start by crossing battery cable terminal and solenoid wire, or push starting the car, will I create a worst problem for myself?
DNK
"TR6 Won't Start Just Clicks"
You sure it's not an MG?
Gerry M
Gerry M
TR3driver
Not likely, IMO. If the starter is that badly damaged already, then it will have to be rebuilt or replaced no matter what you do now.
sp53
Not sure about access to a starter for a tr6, but I looked at some on line pictures and it looks like the back of the armature sticks out from the case and has that square shaft end like a tr3. With a tr3, you put a7/16 wrench on the square shaft on the back of the starter and turn the locked starter back out counter clockwise.
sail
Too simple after all this to just be the solenoid. Push the button in back and wiggle it. In neutral.
J TR6 TR6 died/ won't start Triumph 30
S TR6 1975 TR6 won't start Triumph 3
Phil73 TR6 TR6 won't start Triumph 41
F TR6 Help..TR6 won't start after months of sitting Triumph 33
T TR6 My TR6 won't start Triumph 15
D TR6 TR6 Won't Start Triumph 6
Alfasudcrazy TR6 TR6 won't start when hot? Triumph 10
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
D TR6 TR6 won't turn over -Rookie TR6 owner Triumph 12
roofman TR6 Tr6 won't go into gear Triumph 15
B TR6 1971 TR6 won't idle. Triumph 35
B TR6 "New" TR6 Hood Release Cable Won't Open Triumph 7
tr6web TR6 Rheostat TR6 - won't come off Triumph 6
BierRunner TR6 TR6 Trunk Lock Striker Triumph 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
