TR6 TR6 Dash Support won't go in
Coyote1
I've been trying to get the dash support in place after a restore. My problem is that it won't go down low enough to get it under the control knobs. I removed the sound/heat insulation from under it and still cannot get the legs to the floor board. I need to get it down about 1/2 inch in order to get screw/bolt holes to line up. It feels tight against the new fiberglass tunnel and I suspect that may be the problem.
Any ideas? Sympathy? ???
Larry
Sounds like the trans fiberglass cover is too tall. To make sure remove the trans cover and see if the dash support will fit okay. Is the trans cover black poly or glass. If poly it should bend down enough but you will have to force it in pretty hard.
Later thought - I have used long bolts on the legs and pulled the dash support down into place.
Marv
mallard
Did you replace the floor pans? If so you may have to push them up. Marv's idea of longer bolts to pull it up sounds good if you go slow.
JerryVV
It sounds like you need an additional 1/2 inch overall to fit the support. My guess is that you really don't need that much but it just looks like you do. They are a tight fit between the dash and the floor.
I have in the past placed a jack between the floor and the dash to gain some room. Never for a 1/2" however and if you have the wooden dash installed be very careful jacking and at the very least lossen all of the screws holding the wooden dash to the metal dash behind it and remove the speedo and tach. I'd take some actual measurements of the support upper holes to base and then the same measurement on the car. Also when installing the support you should place the upper portion below the dash and then rotate the bottom into place. It will be tight as it rotates into place.
61tr3
I had a similar problem, I used a floor jack on the passenger side. I set plywood down on the floor pan and used a 2X2 on the jack to lift the dash the 1/2" to get the support in place. I did this with the wood dash not screwd to the metal frame that holds the wood.
davidk
Never needed a 1/2 inch, but I've always had to sit on the tranny tunnel and wedge my legs between the floorboards and dash and push up with my knees. Doesn't sound to glamorous, but it works.
vettedog72
That space seems to shrink while the brace is out. If the brace has been in for a few years you can take it out and replace it easily but if it is out for much time (three to six months or more) it will be a real task to get it back in; even with the carpet cut out or insulation cut out so metal to metal contact can be made at the floor. Jacking the dash up and/or pushing the floor down seems to be what is needed but it is difficult to jack as you no doubt can see. I have some clamps that also work in reverse and plan to try one on each side of the dash. I dont think the real solution is to grind off a little of the bottom of the support but I am tempted.
Coyote1
Coyote1
I pulled the carpet back and tried to fit it again. The fiberglass tunnel kept the base from contacting the floor and it will not flex. The best fix I could come up with was to use an extra support I had (padding removed). I marked the spots it contacted the tunnel and ground them down until I could finally fit it in. I'll paint it with wrinkle paint and use it instead of the padded support.
As several have mentioned, time takes a toll. The support and tunnel were out of the vehicle for ten years.
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
V TR6 TR6 Center Dash Support Triumph 16
G TR6 Dash support options for TR6 Triumph 8
C TR6 TR6 Dash Support Triumph 5
F TR6 Looking for TR6 metal dash support Triumph 4
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Thickness of original TR6 dash Triumph 2
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
G TR6 TR6 dash and windshield frame removal Triumph 13
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
G TR6 TR6 dash lights not bright enough Triumph 22
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 TR6 dash help Triumph 8
I TR6 TR6 Dash help Triumph 7
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
roofman TR6 72 TR6 dash lite reostat question Triumph 10
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
I TR6 TR6 dash refinishing Triumph 7
J TR6 TR6 DASH HELP? Triumph 6
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
