TR6 TR6 Center Dash Support
vettedog72
I looked through the files but I can not see a clear consensus on how to get the center brace relocated after several years of being out. I have received some invaluable gifts of knowledge on this service like the rope trick to get the cylinder head off. I hope there are some good technics for the replacement of the brace.
mrv8q
Hmmm, mine bolted right in..... Bolt holes lined up perfectly. What's your situation?
T
Tinster
Strange, mine bolted right into perfectly lined up holes at
the bottom of either leg..and two at the top.
Are you sure you are asking about the plinth?
DNK
Did you replace carpeting? add Sound proofing.
All makes it a harder deal
BobbyD
It can be tough to line up especially if you've installed new carpet, underlayment and sound deadening. It's also possilbe that the captive nuts have been cross threaded or stripped. I drill mine out and re-tapped them up one size and used new bolts. The only invaluable tool that I use is a big awl that lets me gently or not line parts up. In the pictures below it was used for the mounting brackets on my Miata seats. But I also used it for the dash support.
V
vettedog72
Sorry for the delay but I have a few home improvement projects going at the same time. The carpet was replaced and I wish I was close enough to worry about lining up the holes ha.
V
vettedog72
Tinster
When you leave a project too long things just don't fit back as as easy as they came out; at least not on Triumph body parts. These supports are a known problem if you leave them out for years. Ive had the problem before and somehow worked it back in. I know I promised my self that I would never leave it out for a long period time but I just don't have control of my time then. Now it has been out for many years and I need to get it back PLUS I put in new carpet. Carpet? it would not go in with out carpet; Im not close enough to worry about cutting the carpet yet.
DNK
Mines been out for about 10 years maybe more. Don't even tell me there might be a problem
M_Pied_Lourd
Don,
Nothing that a really big hammer won't solve.
Cheers,
M. Pied Lourd
swift6
If its been out for a while, as in years, there is a possibility that the dash has sagged a little bit. Which could make lining up the support a bit more difficult.
DNK
Shawn, just to clarify. You talking about me ,or the dash
M_Pied_Lourd
Don't know about Shawn, Don, but I was most definately talking about YOU.
Cheers,
M. Pied Lourd
V
vettedog72
Gosh, I was hoping for some kind of ingenius rig that would jack the dash upward; the hammer never crossed my mind. Ha
Tr4dude TR6 tr6 center caps and trim rings Triumph 3
BobbyD TR6 Custom TR6 Center Console Triumph 4
B TR6 TR6 Radio & Center Console ?'s Triumph 12
T TR6 need center radio support tr6 Triumph 4
jjbunn TR6 TR6 Center Console Triumph 11
BierRunner TR6 TR6 Trunk Lock Striker Triumph 2
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
