TR6 TR6 original dash bulbs as bright as newer bulbs
G
I got my replacement bulb holders from RBros the other day and did the rheostat (dimmer switch) replacement job yesterday along with all the bulbs changed and speedo/tach gauge cleaning, etc. The replacement bulb holders use the newer dash bulbs that are spade style with no metal connectors (available at any parts store). After dark, I went out and checked the brightness of the TRF replacement "screw in" bulb that is in the OP gauge and the newer style in the VM and they are exactly the same. Going through the ashtray, I swapped the two bulb holders and again, there is no difference to the naked eye at the brightest spot on the rheostat.
One thing for anyone who has never worked on the back of their TR6 dash without completely taking it out of the car should know. It's a real P in the A but it is easy to see how it can be a nightmare completely removing and then reconnecting everything.
A couple of notable points:
Put masking tape over your lower crash pads to start when removing the wood dash. That came to mind immediately when the dash came forward and needed to rest on the pads.
The wiper switch knob uses a pin plus a spring on the opposite end of the stalk which makes the knob 3 times harder to pull off than the heat control knobs. You think you're going to break the switch before it comes off.
The rheostat knob does not make use of the pin mechanism, even though the spring pin is on the rheostat stalk. It just pulls straight off, albeit extremely hard because of the spring pin.
It does not seem necessary to separate the glass from the chrome bezels when cleaning the gauges and you wont have to replace the fragile o-rings.
Lucas replacement bulb actually did fit and stay in my glovebox light socket.
Norton47
Strikle
I think you can use a small diameter device and depress the pin on the wiper switch and it will come off easier.
The first one I did was as you describe, but if I recall correctly the second, I depressed something and it came off much easier.
FWIW
I TR6 Thickness of original TR6 dash Triumph 2
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
J TR6 What are Original TR6 wheels with Michelin Red Lines worth? Triumph 11
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
brgrmyster TR6 Original TR6 speaker covers? Triumph 2
TR6oldtimer TR6 On a TR6 what was the original color of Triumph 6
G TR6 TR6 for sale original owner Triumph 2
2wrench TR6 TR6 Original Hardtops -- years that fit. Triumph 9
bigbadbluetr6 TR6 TR6 original header question Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
