TR6 Tr6 won't go into gear
roofman
I have not driven my 6 in over a month, and went to go for a spin this morning and:
won't go into gear
clutch pedal feels notchy
new slave cylinder 4-5 months ago
clutch master full of fluid
where do I start?
Norton47
If the clutch feels notchy, could it be the dreaded fork to shaft pin sheared?
Platinum
Start with the least panic issue first: Warm up the engine to normal, turn it off. Put it in second gear, clutch to the board, hit the starter. If the clutch driven plate is rusted to the flywheel that *should* break it free... Be aware of what's in front of you in casae it lights and doesn't free off the clutch!!!! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
BOXoROCKS
"TR6 wont go into gear"...sure it will,..you're just afraid of busting some gears is all...other than that do as DrE suggests. Then let us know what if that worked,...we have many more expensive ideas for you to try.
BOXoROCKS
forgot to add,when one piece of hydrolics is replaced,it inevitably means the other will go shortly. They tag team ya.
roofman
roofman
Well got back from work, tried DrEntropy's unstick the clutch method, and IT WORKED.
Went for a 10 mile run and all is well.
Thanks again.
It has been 100 Degrees most of the last month with stifling humidity, so .......
T
Tinster
enjoy yer drive!! /bcforum/images/%%GRAEMLIN_URL%%/driving.gif /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
d
Brosky
Dale,
See how easily these problems are solved stateside?
Drive Amos over the bridge or through the Miami tunnel and we'll fix him right up for you.
Platinum
Thanks again.
Remember Douglas Adams' calming words: "DON'T PANIC!" /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Glad to hear it weren't anything REALLY serious. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Once in a while you 'rumphy guys amaze me: Takin' th' word of an MG/Lotus/Alfa type on FAITH alone! Very brave. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
roofman
roofman
Although I appreciate it very much you have to admit Doc, there wasn't a whole lot of risk in your recomendation.
Besides I am not one to pooh-pooh others choices of cars. Whatever turns you on is cool by me. It's a great hobby, and as an amatuer tinster I am always gratefull for you guys on the BCF.
Never would have thought one month could cause the plate to stick though. Drove again this a.m. and all is well.
DNK
<span style="color: #3333FF"><span style='font-size: 26pt'>"an amateur tinster"</span></span>
A new term is created. I like it Roofy
T
Tinster
Well Doc/ Roofster-
Sometimes when an amateur person, like yours truly,
is so ignorant of things mechanical to know something
cannot possibly be accomplished, we forge ahead blindly
and once in a while find that silver dollar buried in
the mound of horse dung.
Sometimes we bust a knuckle or two in the process.
d
swift6
Well Doc, if anyone would be qualified to talk about 'stuck clutches' it would be an MG/Lotus/Alfa type that lives in Florida. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Platinum
Bite yer tongue, Shawn. Only ever happened to me personally when I lived up in western PA. Left the "little" Elan sit for a month or two in a dirt-floor garage inna winter. /bcforum/images/%%GRAEMLIN_URL%%/shocked.gif
...though I have seen quite a few come thru the shop here. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
J TR6 TR6 died/ won't start Triumph 30
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
D TR6 TR6 won't turn over -Rookie TR6 owner Triumph 12
S TR6 1975 TR6 won't start Triumph 3
Phil73 TR6 TR6 won't start Triumph 41
B TR6 1971 TR6 won't idle. Triumph 35
F TR6 Help..TR6 won't start after months of sitting Triumph 33
T TR6 My TR6 won't start Triumph 15
D TR6 TR6 Won't Start Triumph 6
Alfasudcrazy TR6 TR6 won't start when hot? Triumph 10
B TR6 "New" TR6 Hood Release Cable Won't Open Triumph 7
tr6web TR6 Rheostat TR6 - won't come off Triumph 6
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
