TR4/4A TR4a ride height question
tdskip
Guys - can some one grab a measurement for the distance from the top of the front wheels to the fender opening? My gap looks big to my eye, but the car is level. It may just be my (overly)lower TR6 playing to tricks on my eyes. :laugh:
Thanks!
HerronScott
Tom,
I'll see if I can get over to the cars for a measurement today (I need to check on some Spitfire parts if I have time), but here's a distance picture of mine after I restored it for visual comparison. This has the uprated springs that TRF supplied back in the early 1980s which were called mild competition grade and which were not supposed to change the ride height.
Scott
Geo Hahn
Just a little less than 2.5" on my TR4, don't think a 4A would be different (but also don't know if mine is anything like correct).
HerronScott
Hey Tom,
Sorry but I've got various states of tire inflation so a little hard to tell but I measured roughly 2.5"-3" between the 2 cars. Definitely take that with a grain of salt! I'd trust Geo's or other members with active cars first. :smile:
What do you have on yours? I think that you'll see some settling with time as well.
Scott
T
tdskip
Uh oh.... Now granted that the hood/bumpers are off and the interior is stripped but I'm at 4.75. I have stock springs in the front, BP Northwest poly bushings and spring plates all the way around. She'll settle some, but not 2 inches.
I thought it might be TR6 roll bar I fitted somehow binding the suspension but no dice, I just disconnected it and bounced her up and down and no change in ride height.
Ugh.
HerronScott
Tom,
Spring plates? Do you mean the aluminum spacers?
I'm pretty sure those are not used at least with the springs that I got from TRF.
Scott
HerronScott
Oh the rubber insulators! Looking back at my picture, I don't think I had any where near 4.75" even when the springs etc were new.
Scott
RJS
Just came in from the garage. I measured from the top of the wheel rim to the bottom lip of the front fender. I just think tire shapes and sizes introduces to many dynamics.
Anyway, on the left side I got 7.75" and on the right side I got 8.25". Running stock/original springs.
PS: edit: I have poly bushings in the front end
T
tdskip
Thanks Scott and Bob.
Ugh - not sure what is wrong here. I'm clearly too high in ride height.
Anything jump out at you as wrong here?
T
tdskip
Here is how she was riding before. I can't make up my mind if that looks right or a bit high here too. What do you think?
T
TRDejaVu
Not a 4A, but here is mine when it was nearly finished.
I'm thinking that the extra gap is partly due to the modern lower profile tires compared to the originals.
HerronScott
Ian,
Good point as my measurements were with original 165-15 tires although don't you aim for tires that end up with the same/similar circumference (wider but lower profile?) so the speedometer is still accurate?
Scott
T
tdskip
Hi guys - so after studying all the pictures it does appear that her rode height - in a similar stripped condition - when I bough her was more or less correct.
Since the only thing that changes were the poly bushings I am assuming that between the a-arms, spring insulators (did I get that right this time Scott?) there is enough extra material that is not compressing to raise her up about an inch.
That seems like a stretch, but what else could it be? Ball joints wouldn't do that, would they?
I guess I could take it all apart again and turn the a-arms upside down? Or maybe the lower fulcrum bracket but I think that would result in the a-arm bolt that goes through the bracket to hit the bracket...
T
tdskip
This is an old thread, but it is my old thread so I figure I can bring it back to life if only to close it out.
This is the $1,500 TR4a IRS that sat for 25 years in a car port, suspension was all goofed up with mismatched parts. When I sorted that all hot she was sitting too high, which I was bemoaning above. I swapped out the rear springs which took care of that end of the car but then she was in a tail-low stance. Not good.
The new Richard Good springs finally went in today, and as with all his stuff they were perfect. I hereby pronounce her level, lowered, and ugly, but ready for fast road use.
Thanks for all of the help and coaching along the way!
Brinkerhoff
How much do the springs compress when the car is on the ground? anywhere near midway in the travel? Did you tighten the inner A arms up before the car was loaded?
glemon
I beg to differ about the ugly comment, paint has a little gloss and shows the cars lines well, always wanted a dark blue one. Anyway she is a beaut, if you make it prettier you will spend more time worrying about door dings and rock chips and less time having fun...
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Zimmycobra TR4/4A TR4A Front ride height revisited Triumph 24
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
