Hi Larry,
I can confirm the throttle pedal stop is nothing more than a standard bolt (looks like 5/16 NF x 1 or 1.5" approx.) that's threaded into a nut that's welded to the front side of the firewall. That's what's on my '62 TR4. It's original to the car.
As mentioned, the dimmer switch platform is pretty simple. It's basically just an angled box folded out of sheet metal. If you had an example, or the specs, it would be pretty easy to make. However, should also be pretty easy to find, too, from just about anyone who is stripping a TR. I'm not sure exactly when they stopped using it, sometime during TR4 production. It also wasn't used on RH drive cars.
It's not shown in the factory spares catalog, but is listed next to the Headlight/Foot Dipping Switch as "Bracket, dipswitch support, 609384, 1 ea." The fasteners used to assemble and mount it are two each: YF7528/screw, self-tapping; FN2045/Nut, fix; HU0505/screw, set; and WP0138/wahser, plain. All the above is listed next to plate AG in the catalog.
The formed sheet metal pieces covering the openings that give access to the wipers are: two each 650159/plate, cover, windscreen wiper access. They are shown on illustration AJ of the spares catalog and use two each 650172/seal, rubber under them, and are fastened with eight YA0403/screw, self-tapping.
Maybe these part numbers will help. The Roadster Factory, Revington TR, Rimmer Bros. and some other vendors reference original part numbers (while a couple other big vendors seemed to feel the need to reinvent the numbering system and confuse things).
A last resort for some of the missing pieces might be Triumphs Only or similar TR specialist. (
www.triumphsonly.com)
Both the bracket for the dipswitch and the cover plates for the wiper box access are simply painted semi-gloss black.
Cheers!
