TR4/4A TR4 front plate seal
HnC
The last time I removed the front engine plate from my TR4 the RTV was so effective that I actually bent the plate while removing it. I think I used the Super Copper Permatex silicone. I will use al aluminum plate on my current assembly and I don't want to repeat the error. I want to avoid leaks but need something less aggressive than the RTV. Can anyone suggest a better sealant?
Thanks!
TR3driver
Great Pumpkin - R.I.P
One of the things I really like about Hylomar is that it never hardens and remains easily removable even many years later. It's a shame the original formula is no longer available; but the "Hylomar Universal Blue" being sold today is pretty close.
Rut
I’m fond of the original blue Hylomar as well as Permatex Ultra Gray and Ultra Black, but Hylomar doesn’t harden.
Rut
TR3driver
Do you like the Hylomar for the rear main "rope" seal too?
Err, you mean the felt on the sides of the rear main cap? I use Permatex Aviation there. Like the book says, cut the felt into sections, soak in the sealer, then tamp them into place. Done properly (IMO), the Permatex oozes out the cracks, showing that the cavity is completely filled.
A "rope" seal is something else. The scroll seal on a TR2-4A is actually an improvement over a rope seal, IMO. (The rope seal on my Ferguson tractor with the Standard engine leaks far worse than any scroll seal I've seen.)
H
HnC
Thanks for that. Yes, I was actually referring to the felt pieces that are jammed along side the rear main cap.I will use the Permatex Aviation. (rather than the Indianhead stuff).
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
S TR4/4A TR4 front and rear suspension Triumph 8
M TR4/4A TR4 front coil springs Triumph 0
M TR4/4A Front Bumper for TR4 Wanted. Triumph 3
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
TR4v8 TR4/4A tr4 front suspension question Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
9 Spitfire Spitfire front clip on a TR4 Triumph 17
KVH TR4/4A TR4 Front Sealing Block Triumph 2
S TR4/4A TR4 front suspension shimmy and shake Triumph 8
nissanite TR4/4A TR4-A Front grill ... How did you restore yours? Triumph 5
Tabcon TR4/4A Help with front input shaft seal on TR4 tranny. Triumph 3
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
M TR4/4A Wanted - TR4 Front Fenders Triumph 9
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
SCguy TR6 TR6 front sway bar on a TR4 Triumph 1
T TR4/4A Moss TR4/5/6 front fender patch question Triumph 2
pa297pass TR4/4A TR4 Upper and Lower Front Valance Panel Triumph 6
SCguy TR4/4A TR4 front end alignment Triumph 2
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A TR4 Front Wheel Bearing Triumph 8
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
Kirk_Fisher TR4/4A TR4 front fenders/engine bay Triumph 13
J TR4/4A TR4 Front Spoiler Triumph 6
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
T TR4/4A Early TR4 - Front Brakes Triumph 3
T TR4/4A what is the ideal front roll center-tr4 Triumph 0
T what is ideal front roll center- tr4 Racing 6
SCguy TR4/4A TR4 front suspension question Triumph 8
TR4nut TR4/4A TR4 front end rebuild - trunnion bushing question Triumph 3
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
TRMark TR4/4A Lowering front of TR4 Triumph 5
mondialo64 TR4/4A TR4 vs 4A front springs Triumph 4
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
