I'm currently working on a project I just brought home. It's a 1960 3A with little rust. The battery box had some rust on the vertical back side towards the top. I've drilled the spot welds and then cut the box loose just below the hole where the oil pressure line goes through. I'm kinda stuck as to where to join the box to the vertical section under the scuttle. It looks nearly impossible to drill the spot welds out. I've thought of trying to cut as much away as possible and then cut m new box to match?
Thanks, Donnie
Thanks, Donnie
