Tip of the day - gaskets
jlaird
When you buy gaskets from whom ever, except for pan and head make a copy on your copy machine then you can make your own when you only need one or a few over a weekend.
JPSmit
good idea - thanks
Better yet, scan them to a pdf and put them in the wiki.
jlaird
jlaird
Trevor, that is an excellent idea but think is beyond my capability.
G
And buy GOOD QUALITY GASKETS !!!!
My cheapy regualr supplier gaskets leaked w/o the motor even running and 2oz. of oil in the engine.
jlaird
jlaird
If it leaks anywhere but the rear non-seal scroll seal it is wrong.
jlaird
jlaird
Only the rear oil seal should leak a drip. nothing else on engine or tranny should.
jsfbond
The very first year I had the car, it sat over the winter and the oil leaked out of the transmission???? Is this a common occurrence? The trans. was then sent to a rebuild co in Georgia (Vinco) that gave me a shorter first gear, and less on the top end.
jlaird
jlaird
It is not normal for the tranny to leak at all. Just a few gaskets and decent sealing on the front and rear with oil inside minimial. Just shy of a quart.
jsfbond
Hey; really, what terminal do I feed on the coil for power?
and how do I test the coil to see if its working?
You need to start a new thread with a subject related to the question so that people that can help know to read it.
JPSmit Today's top tip - Rain X Restoration & Tools 3
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
Geo Hahn General Tech Tip for DOT5 Users Triumph 9
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
Rob Glasgow A tip from You Tube Austin Healey 6
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
Gearhead_Garage Storage Tip for British Cars Austin Healey 10
S Hot tip: seal for fuel tank sender Austin Healey 9
Michael Oritt Rear axle tip needed Spridgets 6
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
glemon Tech Tip, Wonky Switches Restoration & Tools 3
H Su tip Triumph 7
JPSmit Cleaning Tip Restoration & Tools 0
Tinkerman TR2/3/3A Battery Box Liner TR3A Tip for the Day Triumph 5
jlaird Todays tip Spridgets 4
T Reminder on a top tip for stuck bolts Triumph 6
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Basil Tip - Columns in posts FORUM Navigation Questions 0
apbos Undercoating Removal Practice Tip Restoration & Tools 5
B Spray paint tip Restoration & Tools 2
jlaird Need your tranny rebuilt - tip for the day Spridgets 1
JPSmit Good Friday confession - and work tip Spridgets 8
J Tip lowered front suspension and bump stops Spridgets 0
jlaird Tip for today Spridgets 0
Jim_Gruber Heater Valve Leaking - Tip to fix Spridgets 10
jlaird Todays tip, Carbs Spridgets 5
M A tip for those new to Sprites Spridgets 8
D U-joint removal tip any TR Triumph 11
jlaird Another tip for Bugeyes Spridgets 2
jlaird Tip Spridgets 4
JPSmit An installation tip Spridgets 2
jlaird Jacks tip for the day Spridgets 0
jlaird Progress tip Spridgets 1
tomshobby seatback foam tip Triumph 8
sparkydave Random tip of the day Spridgets 2
Stewart Windshield cowl seal hot tip MG 1
E Tip to remove the BMC on a '70 Midget Spridgets 6
RickB Need Tip to remove stubborn headlight trim rings MG 3
SilentUnicorn 1500 Tip of the Day Spridgets 3
jlaird Jacks tip of the day, Spridgets 3
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
jlaird Doors don't fit right-tip Spridgets 3
jlaird More on choke cables-tip of the day. Spridgets 6
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
1 Has anyone ever heard this tip? "Weeping" head MG 11
G AAARRRGH - anyone got a tip for these bushings? Triumph 11
jaybird The 'bird's Tech Tip #17 MG 42
jlaird Todays tip - Door hinges Spridgets 8
jlaird Jacks Tip of the day Spridgets 1
