• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
Tip - Columns in posts
Administrator
Boss
I just ran across a discussion of posting columns in another forum and one of our members (TR3 Driver) taught me something I didn't know. When you try to make columns is a post, by using spaces, it doesn't work because the extra spaces disappear when you save your post. However, it appears that if you type your columns between two UBB "Code Tags" your spaces will say as you intended and thus you can easily put data in columns:
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" ><pre>
Column 1 Column 2 Column 3
Some text Some text Some text
Some test Some text Some text
</pre>[/QUOTE]
But if I try the same thing without the code tags:
By the way, you can enter code tags by selecting "code" from the
menu item in the "full editor" or you can just type a starting and ending code tag manually. It would look like this:
{code}Type your test here{/code}</pre>[/QUOTE] but replace the {} with [] brackets.
Another way to add extra spaces, is to use the ASCII code for "no break space" which would look like this in the editor screen (but becomes a space when you save your post):
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" ><pre>&nbsp</pre>[/QUOTE]
JPSmit Today's top tip - Rain X Restoration & Tools 3
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
Geo Hahn General Tech Tip for DOT5 Users Triumph 9
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
Rob Glasgow A tip from You Tube Austin Healey 6
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
Gearhead_Garage Storage Tip for British Cars Austin Healey 10
S Hot tip: seal for fuel tank sender Austin Healey 9
Michael Oritt Rear axle tip needed Spridgets 6
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
glemon Tech Tip, Wonky Switches Restoration & Tools 3
H Su tip Triumph 7
JPSmit Cleaning Tip Restoration & Tools 0
Tinkerman TR2/3/3A Battery Box Liner TR3A Tip for the Day Triumph 5
jlaird Todays tip Spridgets 4
T Reminder on a top tip for stuck bolts Triumph 6
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
apbos Undercoating Removal Practice Tip Restoration & Tools 5
B Spray paint tip Restoration & Tools 2
jlaird Need your tranny rebuilt - tip for the day Spridgets 1
jlaird Tip of the day - gaskets Spridgets 13
JPSmit Good Friday confession - and work tip Spridgets 8
J Tip lowered front suspension and bump stops Spridgets 0
jlaird Tip for today Spridgets 0
Jim_Gruber Heater Valve Leaking - Tip to fix Spridgets 10
jlaird Todays tip, Carbs Spridgets 5
M A tip for those new to Sprites Spridgets 8
D U-joint removal tip any TR Triumph 11
jlaird Another tip for Bugeyes Spridgets 2
jlaird Tip Spridgets 4
JPSmit An installation tip Spridgets 2
jlaird Jacks tip for the day Spridgets 0
jlaird Progress tip Spridgets 1
tomshobby seatback foam tip Triumph 8
sparkydave Random tip of the day Spridgets 2
Stewart Windshield cowl seal hot tip MG 1
E Tip to remove the BMC on a '70 Midget Spridgets 6
RickB Need Tip to remove stubborn headlight trim rings MG 3
SilentUnicorn 1500 Tip of the Day Spridgets 3
jlaird Jacks tip of the day, Spridgets 3
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
jlaird Doors don't fit right-tip Spridgets 3
jlaird More on choke cables-tip of the day. Spridgets 6
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
1 Has anyone ever heard this tip? "Weeping" head MG 11
G AAARRRGH - anyone got a tip for these bushings? Triumph 11
jaybird The 'bird's Tech Tip #17 MG 42
jlaird Todays tip - Door hinges Spridgets 8
jlaird Jacks Tip of the day Spridgets 1
