Stromberg SU Carburators
pertuso
One of the Stromberg SU carburators on my TR6 does not hold the oil I add through the damper. I recently had both carburators ovehauled. On one I feel the resitance when I insert the plunger. On the other I feel the resistance right after I add the oil but as soon as I drive the car. The resistance is gone. I'using damper oil on both. Some one suggested I'd use a heavier oil. Any suggestions?
Kurtis
First of all, I assume you mean Zenith Stromberg (Zenith Stromberg and SU are two different carburetor manufacturers). The Strombergs have a rubber diaphragm. If I recall correctly, the usual cause for the problem you're experiencing is a torn diaphragm.
Dave Russell
Yoda - R.I.P
Some of the Zenith-Stromberg (ZS) carbs, similar to the SU, have an adjustable metering needle rather than the earlier adjustable jet. I believe this arrangement started in 1972. You didn't say what year the carbs are. The needle height is adjusted through the damper/oil tube with special tools. With this design, the needle holder assembly is isolated from the damper oil chamber by an O ring. If this ring leaks, oil will be drawn out of the damper chamber & into the engine. The O ring can be replaced if you are knowledgeable about the ZS carb.
Kurtis
Shows how much I know about Zenith Strombergs. /ubbthreads/images/graemlins/wink.gif
Kurtis
No no no Dave, I didn't mean to convey that I'd taken offense at your comments... No need for you to apologise. I'm really not that familiar with Z-S carbs. I always thought a torn or punctured diaphram could allow the oil to leak off, but based on your reponse, I assume I was wrong (and that's okay... It's not the first time. /ubbthreads/images/graemlins/shocked.gif).
I should have limited my original post to expressing confusion over the term "Stromberg SU". /ubbthreads/images/graemlins/wink.gif
G
Darn, you guys are nice to each other. Had this been any other forum your comments would be rife with snide remarks and insult. Nice to read a civil exchange at 4 in the morning. (you think I need a life?)
Bill
P
pertuso
Thanks you guys. I guess TR6 Bill is correct. My model is a 1972 CC 78515. The carburators are Zenith Stromberg. That aldo shows how much I know about these things. n I still need help is it the diaphram or an oil seal.
Dugger
You need to replace the needle o-ring [TRF Part no. ZEO19657] located in the air valve asssembly on the metering needle screw.
If you are to going to do this yourself, then you will need the carb adjustment tool.
You can still get the ZS rebuild kits from most auto parts stores as this carb was used by several auto manufacturers for many years. The kits are universal and cover several year makes, so there are some redundant pieces.
This is not a difficult task, but care should be taken to prevent damage to the internal machined parts. Also, air valve assemblies are carb specific (not interchangeable).
bobh
There is an option to buying the adjusting tool. The old GM point adjusting tool will work with a little finesse. It requires one extra step. The point adjusting tool has a handle like a screw driver. The shaft is a spiral wound piece od heavy wire similar to the flexible extensions you can buy for a 1/4 drive ratchet and socket set. The business end of the tool is a straight allen wrench. The adjustment socket in the oil tube accepts this allen wrench end perfectly.
The extra step you need to take is to remove the top of the carb then remove the piston assembly. You must hold the piston in one hand while adjusting the needle with the other. This actually is not a bad way to make the adjustment because you have better access to the set screw that holds the needle in place.
If you buy the fancy tool that keeps the piston assembly from rotating as you turn the adjuster, it's easy for someone who is not familiar with the assembly to ruin the delicate brass pieces by not loosening the set screw.
Whichever tool you use be sure to back off the set screw.
You may have to go to a real parts store to find a GM point adjusting tool I'm sure someone like Lysle still make them. Maybe JC Whitney.
If my instructions are slightly off it's because I haven't adjusted a Stromberg in 30 years. If anyone wants to fine tune the details go right ahead.
P
pertuso
Thanks bobh,TR6 Bill and everyone that replied unfortunately I'm not handy with tools so I have a mechanic do all the work in my car. I will pass on all the good info
regards
Pertuso
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg carbs Triumph 8
R TR4/4A Tr4a, Stromberg rebuild Triumph 6
