General Tech Midget Stromberg 150 Adjustment
TR6BobNF
Hi Folks:
I'm a TR6 driver (former Midget owner too! :cool:) but was helping a buddy with his 1976 single-carb Midget tonight and I brought my Moss mixture adjusting tool to see if I could help out with his carb problems. I know my way around a Stromberg fairly well and how to use the tool but the metering needles on my TR6 move easily with the tool and his just doesn't want to move and although the Allen key fits the needle, indicating that it is in fact an adjustable version I am hesitant to apply too much pressure. Can these needles get gummed up with carbon or varnish requiring the carb to be removed and soaked in cleaner (Gunk) or can I just horse it loose? I know enough to check all his vacuum lines, diaphragm and bypass valve but I'd really like to see if it's running rich first, which it appears to be judging by the sooty plugs and the exhaust and I really don't want to bust a buddy's carb by forcing the needle. Are they pretty robust or should we take it off, soak it and just rebuild it - any suggestions?
Cheers,
TR6BobNF
TR6BobNF
Gee, over 150 hits and no replies. Guess I'll just go back to the Triumph forum and ask them for help. :confusion:
JPSmit
Sorry to say that Zenith Strombergs are a black art for most of us. I took mine off and put on an SU. If you like i can see what the manuals say.
JPSmit
Oh, and just realized this is on the MG forum not the Spridget forum. Might be worth a re-post.
JPSmit
just looked at the manual - and there is no indication of how robust. I would suggest a rebuild - and, FWIW, they tend to run rich, especially if the original air cleaners or the smog equipment is missing.
injunjoe
Bob,
Its been a looooong time since I've messed with a Z/S carb, last 90s in fact, so I'm working with fuzzy memory here. First, I think its probably very possible that the needle is gummed up or corroded to the piston. I know SU carbs suffer this too, so dissasembling and soaking would probably do a world of good here. Take off the diaphragm and soak the piston assembly in a can of carb cleaner for a few hours, or squirt some PB Blaster, penetrant or a 50/50 mixture of atf and acetone to help free the needle. A rebuild is probably in order here so prepare your buddy for that.
Second, John Twist has a lot of great videos as most of us know. Pop over to youtube and check out University Motors Ltd. He has several dedicated to the Z/S carb: one shows how to change the O-ring at the bottom of the piston where the needle resides that keeps oil in the damper tube. The second is a 3 part series rebuilding the water controlled choke. Very informative stuff and may be good to view them just for see how that needle area breaks down. I cant remember if the Midget has a water choke on the Z/S but the MGBs do.
Good luck with the project, let us know how everything turns out, get your buddy on the forum here and remember; we love pictures. :encouragement:
JPSmit
Yes, Midget had a water choke - I changed it for manual - then for SU
TR6BobNF
TR6BobNF
Thanks guys and kudos to Joe for the good advice. My buddy will be happy with that so I think we'll take out the piston and soak it first thing. Will post results (and pics) when completed.
Cheers,
Platinum
The small O-ring around the needle/adjuster is the likely culprit. The ATF/acetone soak helps.
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
