TR2/3/3A Steering Hub Turn Indicator lever
Redoakboo
I had a strange thing happen to my 57 TR-3 on the way to a car show yesterday. When I left home, the turn lever and dash light were working perfectly. As I drove , and used my turn signals, the lever started slowing turning clockwise every time I used it. By the time I got to the show, the lever was at the bottom of the hub? Turn lights and dash light were still working, but now at the bottom of the steering wheel?
I loosen the three set screws on the back of the hub and was able to pull the wheel out about 3". I could now turn the aluminum wheel completely around with my finger but the front ring with the lever stayed in the down position no matter what I did. Is there a way to unlock the lever section so I can return it to the top again?
Dick Vinal
TR3driver
Great Pumpkin - R.I.P
Loosen the compression nut on the front of the steering box.
You'll also want to have the plate turned the right way, or the turn signals won't cancel.
R
Redoakboo
I assume that after I loosen the compression nut, I will be able to turn the lever section back to the top. Then I re tighten the compression nut? Question: What could have caused the lever section to move in the first place?
Thanks, Dick
TR3driver
That's right, reset it and tighten the nut. Usually what happens (IMO) is that the self-canceling mechanism binds and puts extra force on the stator tube. In your case, the tube slipped in the compression nut; but often it breaks the tube right at the base of the slot (under the control head).
Wouldn't hurt to disassemble, clean and lube the head either. Mine seems to need it every 5-10 years or so.
R
Redoakboo
Randall,
Appreciate your usual input. Question: Behind the front piece, with the lever, there is a metal collar that I can turn with my finger. It has a slotted section in it. Before I tighten the compression nut, should the slotted portion of this collar be in a particular location? Maybe up or down??
Dick
TR3driver
Yes. Put the steering wheel in the straight-ahead position (where the car will drive straight), then turn the plate until the slotted fingers are at the bottom (6 o'clock position). Slide the control head into place (seating the plate into the steering wheel), then tighten the 3 grub screws without moving the wheel or head.
This is outlined in the workshop manual, page G16 under "To Fit Control Head and Stator Tube".
FWIW, I recently found a method for drastically shrinking my PDF files. The TR2-3 factory workshop manual went from 200Mb to under 20Mb! So you might want to download a new copy from https://drive.google.com/open?id=0B2H2NJt34OffYWZiN2VlZGMtNTkxMi00NGUzLWE4NzMtMGRkODRkYzU3MDU1
As always, let me know if you find a problem.
PS, not to worry; my doc says I should avoid all forms of alcohol and I never was all that fond of beer anyway. :smile:
R
Redoakboo
Works!! Only problem now is I dropped one of the rear turn lite lenses, wonder if Super Glue will put it back together? Only have 8 pieces!
D Removing the steering wheel hub Spridgets 12
B TR4/4A Steering Wheel Hub Issues Triumph 0
R TR2/3/3A Steering wheel hub removal Triumph 11
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
arizonamike TR6 Nardi steering hub for TR6 ? Triumph 0
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
Tr4dude Edit--gloss level for the steering column and hub? Triumph 4
S Quick Release Steering wheel hub Triumph 1
RJS Fan Hub Clearance Over Steering Rack? Triumph 4
H Midget steering wheel hub question Spridgets 1
H Midget steering wheel hub question Other Cars 0
B Nardi steering wheel hub MG 1
ModifiedBJ7 Steering Wheel Hub Removal Austin Healey 5
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
Branson Steering Hub Spridgets 6
jjbunn Steering Wheel and Hub Removal MG 43
G Steering wheel hub adapters. Spridgets 9
toysrrus Looking for a Series I Steering Wheel Hub Jaguar 8
George Zeck Steering Wheel Hub ? Spridgets 6
R Nardi steering wheel hub Triumph 0
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
