Steering column bushings
JPrisbe
Member
I bought the steering column rebushing kit from TRF and was wondering what is the easiest way to install the bushings?
Should I lubricate them to get them in and if so what lubrication is recommended?
trrdster2000
Hi Jon, I just use axle grease on the shaft and bushing and a hose clamp to compress the tits until you get them started down the shaft and hope you have them lined up. Wayne
tr8todd
If they are anything like the TR8 ones,(urethane) you soak them in really hot water to soften them up first and then push them in. You can also heat them up with a torch. Just don't get too close with the flame. They will go up like a marshmello.
J
JPrisbe
Member
Well the axle grease worked slick as snot... or shall I say slick as axle grease.
Alan_Myers
Another trick with rubber parts is to just spray them with a little WD-40. It makes the rubber slippery, then dries out and leaves it rigidly in place. I've used it on everything from motorcycle grips to golf club grips to the similar steering column bushings on my TR4. (I'm leery about using grease on the white nylon bushings because some greases gradually soften and damage certain types of nylon.)
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR2/3/3A steering column bushings Triumph 8
S TR6 steering column bushings Triumph 5
I TR6 Installation of Delrin steering column bushings Triumph 3
BobbyD Delrin Steering Column Bushings Triumph 2
I TR6 As the World turns -TR6 steering column bushings Triumph 6
SCguy Steering column bushings? Triumph 1
G Steering column bushings MG 0
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
