TR2/3/3A Split Braking System
jfarris
Greetings,
I searched for additions and modifications to split the TR3 brakes into two systems, but can't find anything.
I'm interested in something like the race car pictured below.
Ideas and sources of parts?
Thanks in advance!
malbaby
There are a lot of split system M/C's in wreckers yards off different cars, you may find a compact one that can be adapted to suit your TR3 and still look OK.
TR3driver
Great Pumpkin - R.I.P
Worth noting, perhaps, that with two MCs in tandem like that, the pedal becomes a lot harder. It would be twice, except you can find MCs with a slightly smaller bore.
Also FWIW, if you just split front/rear, you don't gain much. The rear brakes by themselves don't do much, and the TR3 handbrake has no trouble activating them. A diagonal split would give you better brakes if one side fails; but of course is a lot more work to implement.
TRMark
Bronze
I am not seeing the advantages of that system unless you are racing. I can see the advantages of adapting a dual braking system such as TR6 or as Malbaby says about adapting something with power for use and reliability.
martx-5
I fabricated a system based pretty much on what Revington is selling. I initially used two 5/8" bore masters in place of the single 3/4" bore single original. The pedal was a little firmer than with the single cylinder. Willwood recently came out with Girling type M/Cs with 1/2" bores. I installed two of those, and the pedal is now actually a bit lighter than with the single 3/4" cylinder. Pedal travel is a bit more, but not enough to be disconcerting. If you buy or put together a system, I would make sure that you use the 1/2" bore cylinders. The original TR3 system is stiff enough, you don't need to make it stiffer. Revington supplies 5/8" cylinders.
I only did it because well, it seemed like a neat project. In the second picture, I changed the dual circuit reservoir. Initially, I used the original can for the dual circuit, but the look of the piece of wood really bothered me. :wink-new:
The reason that they use a dual system on race cars, is so that they can balance the bias front to rear. In the first picture shown, you can see between the two masters is the mechanism that allows you to do that on the fly. I have a balance bar like that, but didn't install it because as it is now, the fronts and the rears pretty much lock up at the same time.
jfarris
jfarris
Thanks to all who have provided advice and links to solutions. I looked and couldn't find it on Racetorations.
I am not racing the car, but do participate in SCCA autocrosses in the H Street or Heritage Classic Street classes.
The current brakes work very well - later rear axle with larger drums and the Toyota light truck caliper mod on the front.
My thought was for the future when a master cylinder went bad, it would be an opportunity to split the systems.
Art, I like what you did and would be up to that project except for the plumbing, especially downstream from the MC's. The kits come with it all (maybe).
Again, thanks to all who spoke up! BCF is the greatest!
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Brake Failure--The Line Split Triumph 19
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
Boink Split Mini British Motor Corp 0
Boink MGB Split MGB-GT MG 10
G TR2/3/3A Split Steering Rubber Bushing Install Problem Triumph 3
CJD TR2/3/3A TR3 Split Column Triumph 6
J Split steering wheel solution? Triumph 3
G Split loom tubing source Triumph 7
M Split Front Bumper Triumph 1
PAUL161 70 Split Rear Bumpers ??? MG 6
ChrisS Ribcase split washers Spridgets 1
AUSMHLY split-front-bumper Austin Healey 9
I oil snding unit area on engine split Triumph 10
A Rear engine plate split in two! Spridgets 9
W Repairing split in metal water pipe? Triumph 3
V Braking Oil Pressure Austin Healey 16
B A/H 3000 braking system Austin Healey 2
D braking system Austin Healey 14
D BJ8 pulls right on hard braking? Austin Healey 4
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
J MGB Project car done; front end clunk noise while braking MG 4
maxwedge5281 front suspension or braking improvement Austin Healey 25
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
maxwedge5281 dual circuit braking system Austin Healey 29
S Engine Race under hard braking Spridgets 21
tahoe healey clunk on braking. Austin Healey 4
C TR2/3/3A TR3 Tach cable keeps braking Triumph 2
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
QuickSilver Right Snap Under Heavy Braking MG 9
T TR2/3/3A TR3A braking part needed Triumph 11
T TR2/3/3A TR3A braking question Triumph 6
T Braking and tires Triumph 26
P 79 midget braking ? Spridgets 5
1 Car wants to die under deceleration/braking MG 21
GregW Late braking news Austin Healey 4
gsalt57tr3 TR2/3/3A Left turn braking problem [TR3] Triumph 2
A Braking to the right after rebuild. Austin Healey 10
J BJ8 Braking Problem Austin Healey 9
John_Mc Hard braking goes weak Triumph 5
7 Braking Troubles MG 3
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
CARSINC Sprite Electrical System Information Spridgets 2
S TR2/3/3A Lockheed brake system Triumph 7
B Stainless Steel Exhaust System Wanted Austin Healey 5
T TR2/3/3A Brake system question - Triumph 4
T TR2/3/3A Help - Cooling system problem Triumph 7
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
