Spec-Miata Racing
aeronca65t
There's tons of wild Spec Miata videos on the internet.
But here's one that puts a lot of them together. There plenty of obvious mistakes including a point where a guy forgets to put "both feet in".
~Click Here~
(the music doesn't do anything for me....) :sick:
R
RonMacPherson
Wow! They gave these guys licenses????
Looks like body and fender repair people can make a good living working on Mazda spec races..
Eric
Looks like the first lap of an F1 race (except without the favouritism for red cars....)
Monkeywrench
Spec Miata has the best and the worst drivers in all of club racing. Worst since it's so easy to buy one, and the best with all the support Mazda has and the fact that it is a "spec" class.
Here is a video from a front running car
J TR 4 Norris Cam 342S Spec Sheet Racing 1
drooartz MGB Toe-in spec in degrees? MG 6
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
P TR6 British spec TR6 Triumph 8
steveg TR6 Spec needed for correct ride height Triumph 28
S Locknut - rear wire wheel - torque spec? Austin Healey 15
T Dockers Light Green Metallic Paint Spec Austin Healey 2
MikeAH100M 100S Spec Question Austin Healey 5
T Works Healey colour spec? Austin Healey 4
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
Healey Nut Another "le mans" spec for sale Austin Healey 2
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
C Drive/Propshaft Bolt Torque Spec? Austin Healey 8
CinneaghTR General TR Thread spec for AC Fuel Pump Triumph 0
S Bell housing to gearbox - torque spec? Austin Healey 4
smaceng BE heater valve packing spec. Spridgets 10
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
R degreeing cam spec question and procedure Spridgets 23
T M Spec Distributor Austin Healey 3
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
G Spitfire 1500 Spit ring gap spec needed please Triumph 1
A TR6 TR6 UK Spec lights Triumph 16
go_inbroke Torque sequence and spec MG 8
Ed Sweeney TR2/3/3A 1962 Triumph TR3B Original Tire spec? Triumph 7
H "Special engine" spec 290 Austin Healey 1
M Bugeye rally spec rear springs? Spridgets 9
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR2/3/3A TR3 Wishbone bush ream spec? Triumph 8
C Timing spec and curve Spridgets 4
Bruce_B Spec. Needed for 1275 Line-boring - "Housing Bore" Spridgets 13
kyreb1862 MGB MGB Plug Wire Spec's MG 1
D Wiper Motor Color Spec Triumph 9
B torque spec pressure plate Austin Healey 4
L Where to find BJ8 Cam Spec's? Austin Healey 3
ChrisS Spec E30 Stolen - Ohio Racing 2
A steering wheel torque spec Triumph 3
Brosky Finally got my red distributor cap and spec plate Triumph 7
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
TypeRboy Anybody know what an RS spec Escort is? Other British Cars 16
S pitman arm torque spec Triumph 0
A TR4/4A TR4 wheel bolt spec Triumph 5
V TR6 TR6 Wheel Spec's Triumph 4
G Mech Spec Vendor MG 2
Mickey Richaud TR2/3/3A Front End Spec for TR3A Triumph 5
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
