Spec E30 Stolen - Ohio
Bugeye58
There sure seems to be a lot of that happening lately, Chris.
I'll put the word out around here and keep my eys open.
Jeff
Platinum
Who ~does~ this kind of stuff?!?! Makes me want to rig trip wires and traps around the entire hovel... baited.
J TR 4 Norris Cam 342S Spec Sheet Racing 1
drooartz MGB Toe-in spec in degrees? MG 6
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
P TR6 British spec TR6 Triumph 8
steveg TR6 Spec needed for correct ride height Triumph 28
S Locknut - rear wire wheel - torque spec? Austin Healey 15
T Dockers Light Green Metallic Paint Spec Austin Healey 2
MikeAH100M 100S Spec Question Austin Healey 5
T Works Healey colour spec? Austin Healey 4
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
Healey Nut Another "le mans" spec for sale Austin Healey 2
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
C Drive/Propshaft Bolt Torque Spec? Austin Healey 8
CinneaghTR General TR Thread spec for AC Fuel Pump Triumph 0
S Bell housing to gearbox - torque spec? Austin Healey 4
smaceng BE heater valve packing spec. Spridgets 10
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
R degreeing cam spec question and procedure Spridgets 23
T M Spec Distributor Austin Healey 3
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
G Spitfire 1500 Spit ring gap spec needed please Triumph 1
A TR6 TR6 UK Spec lights Triumph 16
go_inbroke Torque sequence and spec MG 8
Ed Sweeney TR2/3/3A 1962 Triumph TR3B Original Tire spec? Triumph 7
H "Special engine" spec 290 Austin Healey 1
M Bugeye rally spec rear springs? Spridgets 9
aeronca65t Spec-Miata Racing Other Cars 3
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR2/3/3A TR3 Wishbone bush ream spec? Triumph 8
C Timing spec and curve Spridgets 4
Bruce_B Spec. Needed for 1275 Line-boring - "Housing Bore" Spridgets 13
kyreb1862 MGB MGB Plug Wire Spec's MG 1
D Wiper Motor Color Spec Triumph 9
B torque spec pressure plate Austin Healey 4
L Where to find BJ8 Cam Spec's? Austin Healey 3
A steering wheel torque spec Triumph 3
Brosky Finally got my red distributor cap and spec plate Triumph 7
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
TypeRboy Anybody know what an RS spec Escort is? Other British Cars 16
S pitman arm torque spec Triumph 0
A TR4/4A TR4 wheel bolt spec Triumph 5
V TR6 TR6 Wheel Spec's Triumph 4
G Mech Spec Vendor MG 2
Mickey Richaud TR2/3/3A Front End Spec for TR3A Triumph 5
TomMull V10 in a BMW e30 [325] Other Cars 4
