Space Saving Hints?
With my recent acquisition of a second LBC and the need to do a little work on it I now find space is at a premium.
Any hints or tips for making the most of what little room I've got?
One car garage (roughly 8 x 17 ft area) presently housing a major Big Healey restoration:
I built my own workbench, with lots of shallow drawers for tools:
This now has a shelf under the drawer on the right. And more welding kit is where the small compressor was- and that's been replaced by a bigger one alongside the bench.
I've put enough shelving up to give about 130 sq. ft. of storage space. And a lot of things get hung on the walls.
Things I don't particularly need are also stored in the attic, under the house and in the garden shed.
Anyone have any space saving ideas?
tony barnhill
Great Pumpkin - R.I.P
Platinum
I just keep pilin' junk on top of the Elan. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
tony barnhill
Check it now...
GregW
Platinum
Hi James,
I don’t have much more space than you, about 10’x17’, so I know your pain. As Steve mentioned on his website, get stuff on wheels. Start with the Healey frame. Put the axle on a 4 wheel dolly and roll it under the frame. I welded up some new shelving while my car is in the body shop. I made the left side shelves start above the height of the car so I could open the door after parking. See 1st attached photo. Seems you could do something along those lines on the same side. Then you could roll the car underneath it to give extra space to work. The second photo shows well, a mess, but I wanted to show you the wrench/ socket set cabinet. It is double hinged so the door with the wrenches opens to access the sockets, then the socket shelf opens to access the shelving behind. Just a couple of ideas to throw around.
GregW
Platinum
Hi Steve,
Thanks, Sears was having a great sale, 248 piece socket set for something like $120. Sans organizer of course. So they had to go somewhere. Turns out they were liquidating old stock, about a month after I bought them they came out with the large label sockets. Oh well, still a good deal.
Steve_S
The big letters are nice, but I have to wonder how durable they will be over a 20 year time span.
I have all my sockets in a drawer. I got a bunch of socket rails and used rivets to attach them into a giant grid. Then I placed socket clips all over it to hold them in place. It works great, but the labels are hard to see. I've been thinking about better ways to do it. A variation on your method might be a good way to go.
tony barnhill
WHEW!
GregW
Platinum
<span style='font-family: Comic Sans MS'>Hi Steve,
I wonder if worn off letters would be covered in Sears lifetime guarantee.</span>
DART
Tony- did you get the narrow or regular width? Is the space between ramps narrow enough for the cars or did you modify it...and if so, how?? and what is the ballpark $$ for the lift? They are nice and compact, and running on 110v is a big plus for me.
BTW, that is one sweet setup you have, not sure I have that many sq. ft. in my entire lot.
tony barnhill
Dale - I bought the GM7000N...the 'N' means the footprint is narrower than the standard model....when we installed it, we moved one ramp inward about 9" to ensure Midgets wouldfit comfortably (MGB's still fit well)...total price was around $2000....but, be prepared with a heavy trailer, 2 men & a boy when you get ready to install! Sucker is heavy...real stable also (I walk around on mine in hte 'up' position with a car up there also.
JamesWilson
Hi Greg:
Your socket rack is a good idea.
I've looked at the mgnuts.com page and I'm already doing virtually all of that. I've got shelving on three of the four walls, down as far as practical (so I don't knock out what little brains I've got), and the lower wall is used for hanging body panels and tools.
The chassis is on sawhorses because I'm still climbing all over it welding and setting it on wheels would be a little dodgy- its still light enough for me to lift and have a help shift the sawhorses if I need to work on the other side- I just need to plan around the moves.
I've sized the shelving to maximize space available. and have a mix of deep and narrow shelves, and some with more clearance for taller items, and some of the shelves have heavy bracing so I can store a Healey head on it.
About the only "trick" thing I've done that hasn't been mentioned has been to have the builder install a roll-up door so it takes a little room above the door but doesn't intrude into the garage- this allows better lighting, access to shelving along the sides.
I've got nearly a hundred little parts bins for hardware and small items on a wall alongside the workbench, beneath the shelves and above floorspace used for my de-humidifier. On the other side I've hung all my air tools- but that's not been such a good idea and I think I'll try to get some kind of roller blind cover for them to protect them from the debris that comes off the stuff I'm mis-treating in my vise.
I'd also thought about using a suspension system with ropes and pulleys so that I could use the space above the floor too. But I didn't do that- it interfere with the lighting too much and I could see myself doing damage to the parts stored and anything beneath them too.
apbos
James
My garage is about the same size 10X20. I've now got my body on saw horses and the frame on a rotisseri made of two engine stands. In good weather I can move the frame out to work on the body or rotate it and work on it in the garage. Not too expensive to build here in the U.S. (about $65). Did a google search and found the plans for it on the net.
Paul
David_DuBois
I would like to make a suggestion to all who have show pictures of their garage/workshops and the items stored on the walls and such. To you on the East Coast, Central US and James over in Scotland, this is going to sound silly, but hear me out. Make sure that everything stored on the wall and over head in the garage is secured against being dislodged by an earthquake. Yes I know that the East Coast and the British Isles are not considered earthquake areas, but there is no place in the world that is totally immune to earthquakes Some of the worst earthquakes in this country have happened on the East Coast and the central portion of the country and all it takes is one moderate quake to knock unsecured items off the wall of from overhead storage on to those nicely restored cars that we all have poured blood, sweat, tears and money into, completely ruining your day. Steve S and I and most everyone living on the West Coast have witnessed first hand what even a moderate quake can do, not to mention "the big one".
Cheers,
C Space Saving Spare Spridgets 10
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
tr6nitjulius General TR TRIUMPHest 2019 Register# Reserved Parking Space# Triumph 0
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
Elva164 Trailer space/race support available for Sebring! Racing 0
S MGA wire wheel space saver spare MG 1
G TR2/3/3A TR3 Replica With Space Frame Triumph 13
BobbyD Space Saver Spare Fits! Triumph 26
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
drooartz Progress: garage space and the final list Spridgets 3
G To Hole or Not to Hole? To Space or Not to Space? Triumph 11
bighealeysource space for top frame on 100-4 Austin Healey 13
G Plan 9 from Outer Space Triumph 3
bluemiata90 TR2/3/3A tr3 spare tire space Triumph 13
S Dropped off the garage space at Drew's yesterday Spridgets 1
Russ Austin Wife's not happy, No parking space! Triumph 8
John_Mc When garage space is limited...... Triumph 3
G Space-Saver Spare Tire.... Triumph 23
E Off Topic Useful for saving some cash maybe? MG 0
S TR6 Worth Saving??? What do you think we should do? Triumph 30
Pythias 1098 worth saving? Spridgets 29
K Saving a clutch disc.....old school method? Triumph 11
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
go_inbroke Saving Old Top Triumph 3
aeronca65t Gas Saving Brits Other British Cars 1
Tinkerman Saving Posts Triumph 9
G Saving Grace for Tinster Triumph 14
Z Fuel saving device Austin Healey 9
S TR6 Saving a TR6 Triumph 1
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
TR3driver TR2/3/3A Practical Hints for the Maintenance of the Triumph T.R.3[A] - Third Edition Triumph 5
richberman E-brake helpful hints Austin Healey 2
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
H Trouble shooting gas gauge...any hints? Austin Healey 9
R 1500 engine rebuild hints Spridgets 33
J hints on rebuilding brake servo? Triumph 9
jsfbond rebuild hints for a carpenter? Triumph 13
GT6_Mark GT6 Tips and Hints on Rewiring GT6, Please Triumph 24
chrisc Wedge Tips/Hints on Edelbrock-Holley TR8 Conversion Triumph 4
Bruce_B Cutting the car for a dual MC setup hints/tricks? Spridgets 23
Bill Redd window crank hints? Triumph 16
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
G Hints from Heloise Triumph 9
txtr3 TR2/3/3A TR3 master cylinder replacement hints Triumph 3
