Snap on front of door
sjuengst
I'm fitting a tonneau on my BT7, and am wondering if the snap on the front of the door should be used or not. It's not mentioned in the Originality Guide, and I can't find any good photos of other similar cars wearing tonneaus to compare. The hardware that came with my tonneau didn't include any snaps, but it looks like a good place for one. What do y'all think?
HealeyPassion
FWIW, I'm pretty sure that isn't an original snap. My 1960 BN7 didn't have it and I don't recall ever seeing that style on an AH.
Cheers,
Steve
bighealeysource
Bronze
Hey Sjuengst,
I've had a BT7 and currently have a BN6, and no snaps on either one.
Would it keep the tonneau from flapping as much at speed, probably, but
not original. If you already have them on both sides and don't want to
fool with filling in the holes, etc, maybe switch out to tenax fasteners
which were at least used on BT7's, BN7's, BN4's and BN6's. Still wouldn't
be correct but would look more correct if that makes sense !
Regards,
Mike
Rob Glasgow
I had an aftermarket tonneau years ago that came with an extra "finger" of vinyl that extended forward around the outside of the right windshield post. The instructions said to install a snap similar to yours at the base of the right windshield post and the female portion of the snap to the tonneau "finger". The design was to keep the right edge of the tonneau from flapping around at speed. I never installed the snaps but it looked like it would have been effective.
D TR2/3/3A snap on headlight rims restore Triumph 10
B Snap Ring Plier Restoration & Tools 3
C "Snap On" Armrest Austin Healey 3
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
T TR2/3/3A Tonneau cover snap install Triumph 14
G Snap locations for BJ8 tonneau Austin Healey 10
B TR2/3/3A carpet snap questions tr3B Triumph 1
MY66AH Coming to a Snap On Calendar near you. Spridgets 9
stretchit2 Snap, Crackle, Pop Austin Healey 11
healeyblue Carpet snap details needed Austin Healey 53
P help: trick to snap and unsnap soft top ? Triumph 11
B Spitfire big bearing snap rings on Spit single rail Triumph 0
T Tonneau snap replacement - any tips? Triumph 11
Newkie Snap, Crackle, Pop! MG 13
S TR2/3/3A tr3 snap studs Triumph 3
QuickSilver Right Snap Under Heavy Braking MG 9
N carpet snap location drawing 100/6 Austin Healey 9
jvandyke someone out to snap this up Spridgets 2
jhorton3 Snap! Spridgets 24
kodanja Snap Crackle & Pop! Triumph 13
N Carpet Snap Posts or Studs Triumph 0
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
R BJ7 convertible top boot cover- snap orientation. Austin Healey 8
healeyboz snap!! Spridgets 6
Aldwyn Snap Questions! Triumph 12
H TR6 Tr6 Booth lid cover Snap Location Triumph 2
T Drive line snap Triumph 1
L Snap ring plyers Restoration & Tools 10
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
