Snap locations for BJ8 tonneau
Goldie
I am planning on installing my new tonneau. The kit comes with 10 lift the dots, 4 Tenax, and 4 snaps. The cover is sold by Moss and was purchased several years ago. Just getting around to installing it as the post on the side window trim was incorrectly installed. I just fixed that problem and now ready to install the tonneau but want to get the snaps in the correct locations.
If vinyl,leave in the sun. Place it on the car and use a wax crayon and feel where the posts are and mark. Harbor Freight sells a set of hole punches that do a nice easy job. If you quickly move a Bic Lighter on the hole it will bind the edges of the hole and form seal to prevent unraveling and stretching of the hole. "Measure twice, cut once". I did one side then moved to the opposite side.
TH
G
Goldie
I really need to know where lift the dot and Tenax go on the tonneau. It appears that Tenax buttons go on the 4 posts that are rear of the doors (around the back of the top. Lift the dot fasteners go around rest of perimeter and the forward flaps with small button snaps on the rearward flaps. Just want to confirm.
Jeepster
I am just about start the same job on my BJ8.
It seems that as you say, the tenax studs go at the rear behind the seats. Lift the dots on the dash and doors. The snaps are to secure the 4 flaps on top of the tonneau ( see my recent post)
With my kit there are also 2 large brass rings that look as if they surround a large approx 3/4 inch hole. I think this is to fit at the rear of the flap that goes over the door sides, the tenax at the side of the car then fits through this hole?
I think you are talking about the post to the rear of the chrome fitting behind the door. The ring goes on the door flap, the tenax "snap" on the rear flap so you can fold the front in and still use the tenax to hold the rear section down. I think you got it right.
G
Goldie
I am not sure why my hardware is different from Moss but I dont have the rings you mentioned. I have 10 lift-the-dot fasteners, 4 tenax snaps, and 4 button snaps. I think I will need the male snaps which were not included. Drawing in the catalog appears to show lift the dot on two of the flaps. I assume that is to secure to the rear seat area when folded behind the front seats but not very weatherproof. I appreciate the help you have provided. Wish I had a diagram and surprised there is nothing in any of my AH books with more detail. Would like to think MOss would include a drawing with the tonneau but that never seems to be included with any of their parts. Moss TV is great for those things that they cover on the net.
G
Goldie
One last question about tonneau snaps. for the forward flaps (without slots cut, just flaps), I would think lift-the-dot snaps would go under the flap but using the Moss catalog, they show as being on the flaps. This would mean the extra tonneau material would fold or roll underneath into the rear seat area and would remain weathertight. If placed under the flaps, then I would assume button snaps would need to be placed on the flap to make it weathertight but they are not shown that way in the catalog. The 4 button snaps are shown on the flaps for the seat belt slots.
CLEAH
The lift-the-dot snaps go ON the flaps, and yes, the tonneau rolls into the seat area.
G
Goldie
Thanks Hugh. Now I can finish this project. Just need to figure out best way to punch clean holes for the Tenax. I have a tool for the lift-the-dots. I may have to make a cutting tool from a metal pipe with sharpened end using my grinder. I haven't looked for a 3/8 hole punch but not hopeful. Got the 4 button snaps on yesterday. Had tools for those. Thanks again for the help.
G
Goldie
Thanks for tip from HF. I also assemble golf clubs and used one of my old metal shafts which I cut into sections to make a hole punch. They are graduated in diameter so I just found the right diameter and cut it there. I sharpened on my grinder but really didnt need to even do that. Didnt need but 4 holes for the Tenax snaps so it held up enough to get nice cuts. The cover sure is tight though. It will be a bear to get on in the winter.
D TR2/3/3A snap on headlight rims restore Triumph 10
B Snap Ring Plier Restoration & Tools 3
C "Snap On" Armrest Austin Healey 3
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
T TR2/3/3A Tonneau cover snap install Triumph 14
B TR2/3/3A carpet snap questions tr3B Triumph 1
MY66AH Coming to a Snap On Calendar near you. Spridgets 9
stretchit2 Snap, Crackle, Pop Austin Healey 11
healeyblue Carpet snap details needed Austin Healey 53
P help: trick to snap and unsnap soft top ? Triumph 11
B Spitfire big bearing snap rings on Spit single rail Triumph 0
T Tonneau snap replacement - any tips? Triumph 11
sjuengst Snap on front of door Austin Healey 3
Newkie Snap, Crackle, Pop! MG 13
S TR2/3/3A tr3 snap studs Triumph 3
QuickSilver Right Snap Under Heavy Braking MG 9
N carpet snap location drawing 100/6 Austin Healey 9
jvandyke someone out to snap this up Spridgets 2
jhorton3 Snap! Spridgets 24
kodanja Snap Crackle & Pop! Triumph 13
N Carpet Snap Posts or Studs Triumph 0
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
R BJ7 convertible top boot cover- snap orientation. Austin Healey 8
healeyboz snap!! Spridgets 6
Aldwyn Snap Questions! Triumph 12
H TR6 Tr6 Booth lid cover Snap Location Triumph 2
T Drive line snap Triumph 1
L Snap ring plyers Restoration & Tools 10
H GT6 Label locations Triumph 2
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
jfarris TR2/3/3A Small Manifold Clamp Locations? Triumph 5
T TR2/3/3A TR3 Gearbox Top Cover OD Switch Locations Triumph 6
C TR2/3/3A Speedometer cable fastener locations Triumph 14
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
B Slot locations for Sprite front emblem Spridgets 2
Patrick67BJ8 Stud Locations - Cylinder Head & Exhaust Manifolds Austin Healey 3
Boink Fuel filters... locations, types... Spridgets 8
Got_All_4 Wedge TR7 PI Relay ECU etc locations Triumph 23
Cottontop Locations of Future Conclaves & Rendezvous? Austin Healey 3
Patrick67BJ8 Red Grommet Locations for a BJ8 Firewwall Austin Healey 4
J Need tenex and LTD fasterer locations for BJ8 Austin Healey 0
G Mounting hole locations Triumph 0
davidk Jack and lug wrench locations Triumph 8
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
SCguy TR4/4A TR4 Voltage stablizer/flasher locations? Triumph 5
B BJ7 Seat Mounting Hole Locations Austin Healey 5
G Mapping locations of Triumphs nationwide Triumph 105
N VIN number locations Triumph 2
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
