Silicone Brake Fluid Warning???
Steve_S
Nothing wrong with Silicon. In the REALLY old days it was believed that standard rubber would not hold up to it, but these days there is no problem.
By the way, silicon fluid does not attack paint. DOT 3/4 eats it like crazy. This is one of the advantages of silicon.
LarryK
For an old car and a restored one at that silicon is the way to go. You do have to bleed and renew the system every couple years as silison does not mix with water and can let water stay in a spot to corrode. Does not eat paint makes it excellent. The only draw back is the temp rating if you want to do any track days. But for the older driven classics it is the way to go. For track days there is a high temp silicon, but depends on track, as some limit the use of silicon because of clean up issues.
PAUL161
I always thought Silicon was pretty slick stuff!
Ok, Ok, sorry.
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
steveg Silicone brake fluid conversion - existing system Austin Healey 41
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
B Silicone brake fluid Triumph 15
bighealeysource switching out brake fluid from silicone to Castrol Austin Healey 4
R silicone brake fluid Rover / Land Rover 5
bighealeysource silicone brake fluid question Austin Healey 3
L Use of silicone brake fluid Triumph 16
HAN8L1965 Brake Fluid- Silicone? Spridgets 7
angelfj1 Silicone Brake Fluid Warning??? Triumph 26
B Changing to Silicone Brake Fluid Spridgets 18
BritCarFan Silicone brake and clutch fluid British Motor Corp 7
RobT Silicone Brake Fluid & Swelling Seals Triumph 6
6 silicone brake fluid Austin Healey 24
P Silicone Brake Fluid Restoration & Tools 20
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
K TR4/4A The "silicone type" valve cover gasket? Triumph 3
mgedit TR2/3/3A Justin Wagner Silicone Valve Cover Gasket Triumph 2
Gliderman8 TR6 Silicone valve cover gasket Triumph 4
BobbyD General MG Gasket Innovations - Silicone Gaskets MG 2
BobbyD Gasket Innovations - Silicone Gaskets Austin Healey 1
BobbyD General TR Gasket Innovatons - Silicone Gaskets Triumph 8
Healey Nut Silicone or regular Austin Healey 8
CJD TR2/3/3A TR3 Brakelight Switch and Silicone Fluid Triumph 17
BlueMax Silicone hoses kits down flow radiator Spridgets Spridgets 1
Gliderman8 Silicone Gaskets Triumph 18
bighealeysource silicone valve cover gaskets Austin Healey 2
M Silicone Rubber Gaskets? MG 1
theleisure Silicone or Synthetic, How to Tell Spridgets 5
angelfj1 TR5/TR250 TR250 now has Silicone Brakes but no Clutch! HELP! Triumph 42
Brosky Wagner's Silicone Valve Cover Gasket Triumph 8
Brosky Tomorrow, Justin's Silicone V/C gasket Triumph 12
hilsideser to silicone or not to silicone, Triumph 11
2wrench Rear oil seal...silicone or not? Triumph 30
hilsideser Foamy silicone fluid in master cylinder Triumph 22
2wrench Re: Fancy green silicone radiator hoses Triumph 10
roofman TR6 TR6 silicone valve cover gasket Triumph 9
roofman TR6 TR6 silicone valve cover gasket Triumph 2
Brosky New Silicone Valve Cover gasket arrived Triumph 26
Don Elliott Removing Silicone Fluid before Painting Triumph 7
C Silicone on wire wheels? Triumph 16
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
sultanoswing Question about silicone sealers MG 5
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
