Gasket Innovations - Silicone Gaskets
BobbyD
I just heard from Joe Alexander, via FaceBook, that he has bought the Gasket Innovations business and products and now has a whole line of silicone gaskets for a wide variety of cars.... 6 different gaskets for Healey's alone. You can check it out here: https://www.gasketinnovations.com/ind...et-innovations
bighealeysource
Bronze
Hope he comes out with an oil pan gasket ! I have used the valve cover gaskets for a few years and work great.
BobbyD General MG Gasket Innovations - Silicone Gaskets MG 2
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 9
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
B Bonnet hinge gasket Spridgets 10
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
R BJ8 Cylinder Head Gasket Austin Healey 38
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
B TR4/4A Head gasket won't lay flat Triumph 13
T TR6 TR6 Carb Gasket Sealing Triumph 1
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
K Gearbox Throw-out pin and gasket question Austin Healey 8
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
F Sump Gasket Question Austin Healey 15
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
F Heater valve/tap gasket- Install dry? Austin Healey 10
steveg Strange gasket pieces Austin Healey 5
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
Lin Oil sump gasket replacement Austin Healey 31
vette Valve Cover Gasket Austin Healey 18
