Seven years later
a40bob
Well, after nearly seven years of dragging my feet, the old saloon is at the paint shop. Phonepics 011.jpgHere are a few images selected from this time.Phonepics 021.jpgI never intended to go frame-off.Phonepics 154.jpgHere's the last pic before paint.Phonepics 215.jpgThe reassembly will be the fun part!:wink-new:
JPSmit
gorgeous!
a40bob
a40bob
This was a running car when I bought it, aside from the fuel tank, which I removed and had cleaned and coated, and I have not yet seen fit to dismantle anything that's operational. I am prepared to do cosmetic things like cleaning and detailing the frame and engine compartment, replacing the wiring harness, and making sure that all of the electrics work. With the limited driving I have done so far (about 15 miles) I have not encountered any trouble. Thanks for asking!
a40bob
a40bob
I certainly would like to find a trim strip for below the rear window. Mine has a bit broken off. I suppose I could manage with one of the door trims, cutting and welding. My dome light lens is also damaged.
number6
Try Woolies trim in the UK, they may have what you need.
JPSmit
I might <might> be able to help you with that. I know a fellow (previously mentioned) who has a number of these in his back 40. I will likely be trying to connect with him this summer if you aren't in a hurry and send really really explicit instructions on what you need and how to remove it.
a40bob
a40bob
Thank you very much for your response! The trim strip that I am after is a 6 foot long bit of stainless that goes on the outside of the car above the boot lid and below the rear window. It is held in place by 13 nuts that are revealed by removing the headlining around the rear window. If the studs break off during removal, no worries, I already have replacements. I am indeed not in a hurry; it has taken me 7 years to get to this point. Very kind of you to offer your help! I can certainly compensate you for your trouble; we can come to an agreement about that as we progress.
JPSmit
let me see what I can do
D For Sale 2007 Caterham Super Seven Hayabusa 1400 Austin Healey Classifieds 2
M Austin seven ulster Other British Cars 17
regularman LA Seven Mary Three and Four Spridgets 1
DanNagy Spitfire Avatar Change - Spit or Seven? Triumph 7
Brosky Seven months of hibernation over..... Triumph 19
78Z Austin Seven Ulster 3D render Other British Cars 6
jlaird Seven min of spridget video Spridgets 3
S Seven Series IV Lotus 3
G Yeh, I know it's not really a Seven! Lotus 14
78Z My Seven is now a roller! Lotus 31
S 1971 Seven Lotus 13
jaybird Info on Super Seven Lotus 12
C Seven Clutch Again Lotus 1
C Seven Clutch Lotus 4
aeronca65t TRV Seven Lotus 1
G Lotus super seven 1964 Extra car to buy Lotus 1
78Z Lotus Seven restoration video Lotus 35
pbraun Wanted : Seven to buy Lotus 6
C austin seven dynamo brushes Other British Cars 7
Ed Sweeney Seven Shop in Oregon info MG 2
Sherlock New Lotus Seven kit car - Stalker V6 Lotus 4
J 2003 Caterham Super Seven Roadsport SV Lotus 15
TypeRboy Movies! - Lotus Elan and Seven! Lotus 1
Nelson 62 years and holding Spridgets 3
S 10 Years Spridgets 3
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
D MGB 1975 MGB 20 Years Resurrection MG 1
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
tr6nitjulius TR6 Celebrating 43 years Triumph 2
JPSmit 60 years - Mg Midget Spridgets 0
jlaird MGB Don't post like I did 10 years ago. MG 7
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
S 50 years ago this week... Spridgets 7
M 2018 News Years resolution Spridgets 2
S Five Years Ago Today... Spridgets 7
Rob Glasgow A few Years in Between Austin Healey 20
B GT6 I'm back after 8-10 years !! Triumph 1
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
CLEAH My Healey Story, 40 Years On Austin Healey 13
D Lilly first time running in 15 years.... Austin Healey 19
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
3798j Off Topic Fifty Years Ago, Me & My TR3 Triumph 17
drooartz MGB Same car, same spot, 6 years apart MG 12
E TR4/4A TR4 Start up after 35 Years Triumph 1
CessnaTPA USA Import Years? British Motor Corp 2
