My Seven is now a roller!
78Z
please excuse the messy garage but I finally got my Luego Seven to the roller state. Still need to do the panhard rod mount. I think I'll wait until the last moment to position that. Couldn't resist tossing on some of the bodywork and wheels to see how it will look. Nothing is attached which is why its all misaligned.
Suspension bolts aren't on in the picture but I just got all them in. That was much harder than I thought. The bottom ones have to go in first otherwise they are impossible to put in (guess which I put in first).
I have the tranny ready to go in (mount created and welded in). Then the engine hopefully by the engine of the week. After that its a whole huge pile of little jobs - mostly plumbing - brake lines, clutch lines, fuel lines and of course all the electrical. I should have it ready just in time for winter!
BIBBER
Wow! looking nice...now if you had some REAL buddies they'd push you around the neighborhood!! keep posting pics..
aeronca65t
<span style='font-size: 17pt'>WOW! </span>
Excellent job, Dave. I knew you had *plans* to build one of these things, but I didn't know you were coming along so well on one. Looks great!
<span style='font-size: 8pt'> My garage is *much* worse.</span>
Platinum
What's to power it?
78Z
78Z
Thanks folks.
I actually feel - slow - had the parts for almost a year now but only starting to really make real progress now.
Did you ever start that Austin Seven replica project?
The engine is going to be a Toyota twin cam four cylinder from the mid 80s Corolla GTS (also MR2). T50 gearbox (also from the rwd GTS). My engine was rebuilt (not by me, but previous owner had it prof rebuilt) and has 600 miles on it. I have the stock fuel injection (115hp) or a set of Weber carbs (plus and the related timing stuff - 125hp). I think I'll go carbs but we'll see.
I've test fit it and looks like it should work ok - just have to put in for good.
aeronca65t
78Z said:
.....Did you ever start that Austin Seven replica project?
Yeah...it's rolling and has the 1275 in it.
But I'm stalled due to a big project at work that is killing my summer,....plus I'm doing wings on the plane.....and building a second race car with my son-in-law....and racing. The Austin Seven will likley move forward more this winter....or whenever I retire.
tony barnhill
Great Pumpkin - R.I.P
WOW!! How'd I miss this project...are there other threads about it? Is this a kit or did you fabricate/weld the chassis yourself?
78Z
78Z
I was going to weld up the frame myself but wimped out and bought one I found out we were expecting our third child. The chassis and bodywork are from a UK company called Luego. All the rest is sourced all sorts of places. For example engine and gearbox are Toyota, gauges and fuel tank are Triumph Spitfire, front spindles are Hyundai Stellar, etc. There is a probably one or two old threads about it but this is the first real progress I've made since Christmas.
78Z
78Z
I still need to measure things up to drill the holes for mounting the engine mounts but it looks like everything will fit. Gearbox is in. The exhaust manifold is looking a little iffy so custom headers might be needed. (Carbs will move over a little once that wood bit is removed - engine will go down slightly.)
Camshaft
Great read, I love Lotus replica build threads...they only make me want to do one of my own even more!
tony barnhill
Hoo! That's gonna be a little screamer - I call "SHOTGUN"!!
Platinum
Where did you get a Weber manifold to fit to a Toyota T/C?
78Z
78Z
The guy I bought the engine had it. They are around - I think you can buy them new on the internet somewhere. Not cheap of course.
R
RonMacPherson
Weren't the formula racers running these a few years back? Sort of Toyota's version of Formula Ford/Continental.
78Z
78Z
There is also laer twenty valve version (sold in Corollas we didn't get) that puts out almost 200hp stock.
78Z
78Z
Just fits this engine!
Engine mounts fabricated, engine installed, radiator on and carbs (dual Webers) on - fit is perfect.
R
RonMacPherson
Looks good.
Question.
On the carburetor it looks like the JCWhitney type fuel pressure regulator. If so, I recommend, and I'm sure others with experience will add to it, to get a proper regulator?Holley, etc. Or a facet electric low pressure pump. They make one for aircraft that produces 30 gph and around 2 1/2 psi for under 35 dollar.
Platinum
Totally agree. First time that knob thingie changes itself to 5 or 6 PSI and gas starts pouring out the carb throats you'll understand. Hope the engine is cold and the electrical connections are good... I've seen more'n one of 'em make a right mess of an otherwise nice car.
D For Sale 2007 Caterham Super Seven Hayabusa 1400 Austin Healey Classifieds 2
a40bob Seven years later Other British Cars 13
M Austin seven ulster Other British Cars 17
regularman LA Seven Mary Three and Four Spridgets 1
DanNagy Spitfire Avatar Change - Spit or Seven? Triumph 7
Brosky Seven months of hibernation over..... Triumph 19
78Z Austin Seven Ulster 3D render Other British Cars 6
jlaird Seven min of spridget video Spridgets 3
S Seven Series IV Lotus 3
G Yeh, I know it's not really a Seven! Lotus 14
S 1971 Seven Lotus 13
jaybird Info on Super Seven Lotus 12
C Seven Clutch Again Lotus 1
C Seven Clutch Lotus 4
aeronca65t TRV Seven Lotus 1
G Lotus super seven 1964 Extra car to buy Lotus 1
78Z Lotus Seven restoration video Lotus 35
pbraun Wanted : Seven to buy Lotus 6
C austin seven dynamo brushes Other British Cars 7
Ed Sweeney Seven Shop in Oregon info MG 2
Sherlock New Lotus Seven kit car - Stalker V6 Lotus 4
J 2003 Caterham Super Seven Roadsport SV Lotus 15
TypeRboy Movies! - Lotus Elan and Seven! Lotus 1
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
T TR4/4A Question on countershaft gear roller bearings Triumph 4
TomMull Bead Roller Restoration & Tools 0
TulsaFred Throwout bearing: roller or carbon? Spridgets 9
J Sourcing Roller Rockers Austin Healey 23
DanLewis 1.347 Roller Rockers? Spridgets 3
Jim_Gruber Roller Bearings Spridgets 5
JPSmit Roller Spotted 5
D Almost ready to start roller paint job Spridgets 4
D DIY-Roller-Throw-Out-Bearing Spridgets 2
RAC68 DIY Roller Throw Out Bearing Austin Healey 14
W Roller rockers, are they worth it? Triumph 9
Rut Roller vs carbon throw out bearing Spridgets 17
SilentUnicorn Roller Throw Out Bearing MG 11
K tapered roller bearings Spridgets 25
W Will 195/65/15 work as "roller " tires ? Austin Healey 3
TonyPanchot roller rockers Triumph 4
Hap Waldrop Titan 1.5 roller rocker arms Spridgets 33
Tabcon TR4 Roller Rockers...what I have learned... Racing 18
B My roller rockers hit Ebay Spridgets 0
Tabcon 1.65 roller rocker dilemma Racing 18
hondo402000 TR6 TR6 Roller rockers Triumph 11
TonyPanchot Roller Rockers on EBay Triumph 3
Tabcon Roller rocker arms brain teaser... Triumph 9
Tabcon Roller rocker vs. stock? Racing 15
T Any Latest on the roller paint jobs? Triumph 1
Got_All_4 TR5/TR250 Roller Rocker Problems TR250 Triumph 7
