Rivnuts anybody
catfood
A friend of mine who has just built a replica Stratos was horrified at the thought of using self tappers to attach the p-clips etc. He recommended rivnuts. As I'm not averse to improving things where I can has anyone used them or got any opinions?
BigGreen
Somewhere on this forum I saw someone use them for attaching the heat insulation near the exhaust
Self tappers tend to break the material (forced by the thread), rivnuts don't
PAUL161
Rivnuts are cheap, the proper insertion tool isn't. Unless you have enough use to warrant buying the tool, rent one if you can. JMHO, PJ
Roger
Bronze
For the limited use it gets, I have found the Harbor Freight tool perfectly adequate for setting Rivnuts and not too expensive at $20 or so.
Rivetnuts and (primarily, nutserts) are holding most of my car together! Also use them on BMW mods too.
Ironically, I bought the set__tool and an assortment os styles and sizes__to fix an aluminum screendoor, back in the the 80s. For my application, buying the best quality tool paid off, as it has seen regular use for over two (>2) decades, and is none the worse for wear today.
Nutserts in practice:
Keoke
I've had rivnuts spin on me (factory installed). What a pain to get the screws out when that happens.
I was afraid of that so i always coated the nut with JB Weld before i set it none came loose.:applause:
Healey Nut
Rather than trying to remove the screw/bolt when the insert spins . Tighten it and further collapse the insert to tighten it in the hole then remove the screw/bolt .
I did some today on the Vantage for my custom front licence plate bracket , all worked like a charm .
GregW
In my situation, the rivnuts spun freely, including in the righty tighty direction. It was one of those arcade basket ball games that I had to dismantle enough to get it into a bar set for a TV show. Wound up grinding the screw heads off.
Michael Oritt
I had the same thing happen with a custom aluminum radiator. The mounting points were via Rivnuts and one of them spun freely and I could neither tighten nor remove the machine screw used to mount the rad. Ultimately I was able to jam the insert by working a very sharp chisel under the shoulder which allowed me to remove the screw. The failure was probably a function of both the aluminum's softness and the thin section which would not stand up to normal tightening torque. I ultimately removed the Rivnuts and had the holes welded up so that they could be drilled and tapped.
I think they are a great tool when used in the right place, esp. where a fastener must be removed and reinstalled, etc. They are definitely better than running a tapping screw into sheet metal.
steveg
U-nuts are an option for hidden areas where things have an edge nearby. I'm using them on my heater blower mounting feet and some hidden stuff behind the grille. You won't have the spinning problem.
roscoe
Nut clips as Steve illustrated above are available for coarse thread style sheet metal (PK) screws, often referred to as Tinnerman nut plates, or machine screw thread pitches as his illustration shows. Some even have floating but captured nuts in them so that you don't have to line all the holes up exactlly. Tinnerman nuts are available through most aircraft supply houses. I've used them in some places where you won't see them and the sheetmetal screw holes were hogged out due to repeated use and became oversized.
pan
Did you know than all BN1s have one rivnut installed from new? The gearbox oil filler plug hatch is located with one.
And the transmission tunnel, being aluminium sometimes allows the nut to spin!
catfood
catfood
Thanks for the comments guys. I bought myself a tool and some stainless steel rivnuts at the Practical Classics show yesterday. I'll have a practice on some scrap and see how I get on before using them in anger.
That's a very good approach!
It's critical to use the right size drill-bit for the application, and NO WALLOWING out the hole; I especially like it when I have to use some force to get the nutserts into the hole (my preference over the rivet-nut variety).
When possible, try to find inserts that are knurled around the top; these will bite into the panel much better, resisting any tendency to spin out.
And lastly, you may have to play with how much pressure you use when setting the insert; too little and it will spin right out, and too much can damage the internal threads of the insert from the much harder mandrel acting against it. If you have a squeeze-type tool, unless you have really big hands (in that case, you have my sympathy when trying to work on sportscars!) it's hard to crack the insert started, and get it set all in one pull. My method is to adjust the insert in the tool so that I don't have to spread my hand very far; 1st pull cracks the insert's deformation phase, and then I keep turning the mandrel into the insert and giving a little more squeeze, walking it home.
Doing it this way, I also am aware of the first sign of the mandrel getting too tight in the threads, and know when it's done. Even so, I sometimes have to use a pair of pliers on the end of the mandrel (the mandrel's holder, to be precise) to loosen it enough to remove the tool by hand.
steveg
Pegasus has rivet nut setters in fine threads for $11.99.
I ordered the 10-32 and 1/4-28 models:
Rivet nuts are available for good prices from Hansen Rivet in Pacoima, CA.
Michael Oritt
Rivnuts are elegant but require a special tool and can spin, etc. U-nuts are primitive and can only be used on the edge of material but they are cheap to buy or replace and will not let you down. I have one installed at the front of my CAB where a custom round-to-square adaptor for the fresh air hose attaches.
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Csarneson Anybody feeling optimistic? Or drunk? Austin Healey 21
Keoke Anybody heard: Austin Healey 9
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
Gerard Anybody have...? Spridgets 9
TRMark General Tech Anybody Using Star Tron Triumph 2
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
J anybody tell me why this thread closed? Austin Healey 4
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
TomMull Post-War Other Anybody interested in 10s? Triumph 15
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A Anybody finish their car in laquer? Triumph 18
64Elan Anybody interested in an Italian Spridgit? Spridgets 3
Gerard Is anybody able to ID these racing/sports seats? Spridgets 0
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
S Anybody tried this Alternator ? Austin Healey 11
W Anybody have one of these surplus? Spridgets 5
krswen TR2/3/3A Anybody own TR3 TS 59719 L? Triumph 0
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
DNK Wedge Anybody have any "good" adhesive? Triumph 2
B anybody know how and where I can get the cable ends for the heater cable? Spridgets 13
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
J Anybody need a 1500 motor? Spridgets 2
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
Gerard Does anybody have a busted crank? Spridgets 3
regularman Anybody in Arkansas? Spridgets 2
rkep01 Anybody have one of these available? Spridgets 7
regularman Anybody got any cheap used distributor parts Spridgets 8
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
T Anybody Want to Play "Identify the Crud"? Triumph 2
DNK Anybody? Triumph 3
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
DNK Anybody have .. Lotus 1
jdubois Anybody tried these floats? Triumph 7
DNK Anybody need an Eclat Lotus 4
longbridgehealey Does anybody know this car?? Spridgets 0
DNK Anybody... Triumph 12
jdubois TR6 Anybody interested in a TR6 in boxes in MA? Triumph 16
Tr3aguy Anybody got 44k Triumph 16
L Anybody used.... Spridgets 9
S Anybody need a grocery gettery??! Other Cars 10
jjbunn Anybody near Fort Walton Beach, FL ? Jaguar 7
