Question- and todays is
jlaird
Front brake cylinders and lines and such.
There is a small hard line that goes between the the cylinders as I rembember and have and a flex hose that also is hooked in there someplace. Only two places on the cylinders, and three things to connect?
Can not seem to remember and can not find a pic.
bugimike
As I recall there are two different cylinders for the front. one has accomodation for the hard line (bridge piece) and the other has two for the hard line and flex hose. I have switched to front discs, but will dig out the old stuff and take a look for you
jlaird
jlaird
Hmmm, gona go look again, know I orderd lefts and rights.
And I have lefts and rights. Each has two drillings for bolts and two drillings for brakes. One for bleed screw and one for a line. I know a cross over goes there someplace and the flex hose as well. Just how is the question. /ubbthreads/images/graemlins/nopity.gif
bugimike
just dug it all out. I was wrong - there are two holes in each cylinder. The way it works is the hard pipe goes from cyl. to cyl. in the top holes. the flex pipe goes into the rear lower hole, and the bleeder into the forward cyl. lower hole. hope that helps.
bugimike
OOps, I may have been looking at the whole thing upside-down since it is sitting in a drawer and not on the car, so disregard the top and bottom referrences from before, they may be wrong, then again....but the routing is correct - four holes - two for hard line one for flex and one for bleeder.
jlaird
jlaird
Yep, think so. Factory manual says only one bleed screw farthest away from the master cyl. Hehe, came with new bleed screws in all of them. Bumfusiling, it was.
Thanks.
edit: Yep, got it.
fordtrucks4ever
A picture is worth a thousand replies. Unfortunately my camera makes everything look more rusted that it really is...
JPSmit todays's job - and a question Spridgets 25
JPSmit Todays question - wiring Spridgets 14
jlaird Todays strange question Spridgets 6
jlaird Todays question Spridgets 1
JPSmit Todays question - relays Spridgets 13
jlaird Todays crazy question Spridgets 8
jlaird Todays question Spridgets 15
jlaird Todays question - brake drums Spridgets 7
jlaird Todays question Spridgets 16
jlaird Todays question, fans Spridgets 12
jlaird Todays question Spridgets 6
jlaird Todays question Spridgets 3
jlaird Todays Question Spridgets 15
jlaird Todays dumb question Spridgets 2
jlaird Todays question Spridgets 4
jlaird Todays question, no lead head Spridgets 7
jlaird Todays question number II Spridgets 10
jlaird Todays extra credit question is... Spridgets 1
jlaird Todays question of intrest Spridgets 4
jlaird And todays question is Spridgets 2
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
