Possible being stationed in Virginia
PATR8
OK, I found out that I will most likely spending some time (a year) in the DC/Arlington area. I will probably be living in highrise and with all the congestion will be taking my "8" to do my driving. I need to figure out a way to get some garage time to do the regular Triumph maintenance. Are there any suggestions? Any one know of any Triumph Clubs in the area? Thanks
bricktop
Check "Capital Triumph Register" on the web. I just joined a month or so ago. I have not attended any events yet, but they do seem to have some things on the upcoming calendar.
It might make sense to get aligned with a local garage given the storage situation with high-rise Arlington living. London Auto in Falls Church is where I take my 6. Motorhead in Fairfax is another option.
Carter
PATR8
PATR8
I will definately look up Capital City Triumph, I am hoping that FT Myers/Belvoir has a garage where I can rent space. I do most of the work myself, I am more concern where to find some expert advice and an occasion second opinion.
PATR8
PATR8
OK, I can not find web page for Capital city Triumph..... a little help here? I did see a MG club but their web page no longer works
aeronca65t
69tr
Back in the day there were hobby shops on base/post where you could work on your cars. They had most common tools, lifts etc. You might need to reserve a time.
Just a thought, Pete
Lionheart
They still have them. I use the one here at McGuire AFB quite regularly. They charge a couple of bucks per hour for a stall.
philman
don't they have an auto hobby shop on base? most bases have one.
PATR8
PATR8
I am in the process of touring the local bases hoping they have something just like that. I woud like to be able to work on my car on a lift like they had at FT Benning in their stalls. Worst part is I have a TR7 shell I am preping to do a heart transplant on (drop my 8's engine in) working on getting the body ready for the paint but it looks like will have to wait until I get back home to complete that. I will definately have to address rust on my doors and a few spots here and there to keep my 8 presentable, and my window regulator on my driver's door that only sometime works.... and my kids are worried I will be bored but with this much work to do, i will be busy all week.
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
