TR4/4A Plenum Drain hoses
shoopal
Just bought a set from Moss. They look like 2 ft of 1/2" garden hose for $15 a piece! The question is: Do they run down the inside of the carpet boards and into the rocker panels? They are too big in OD to fint through any of the holes in the "A" pillar.
Thanks
Al S.
charleyf
These drain hoses run down the inside of the front fenders. They stop just above the sill and you will notice that in the sill there is a indentation of about 1 and 1/2" wide by about 1/8 to 1/4" deep. This indentation is intended to allow any drain water to run down and out from behind the fender. They seem to work. Some folks have advocated running that hose all of the way out and I did on one car but now believe the extra effort was wasted.
Charley
S
shoopal
Hi Charley.
What I get from your description is that the hose goes from the plenum drain tube, through some hole, down the inside of the fender along the "A" post and terminates in that well.
The hoses I got from Moss have a smaller OD than any hole I can find but I have to admit that there is a lot of sheet metal patching near the bottom and any hole that might have been there is long gone. Of course I have a hole punch that would do it but I wanted to confirm where the hose exits the cabin into the fender area.
Thanks
Al Shoop
charleyf
That hole through the side wall is fairly high . I recall that the hose portion inside the cockpit is fairly short. Then yes it terminates forward of the A post by about 4-6".
Charley
J TR5/TR250 TR250 Rusty Plenum Triumph 2
R Valve Drain Pipe Austin Healey 13
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
Sopwith_Camel battery drain Jaguar 35
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
S Install drain cock in radiator. MG 2
B How big is the floor pan drain hole? Spridgets 0
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
R MGB BATTERY DRAIN MG 7
D Socket for TR3 Gear box drain plug Restoration & Tools 6
D TR2/3/3A Battery Box drain Triumph 9
chicken Holes for Drain Channel Pipe Austin Healey 4
B TR4/4A Oil Drain plug size Triumph 14
T BJ8 Drain Channel Removal Austin Healey 2
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
K TR2/3/3A Radiator drain tap? Triumph 4
Lin Intake manifold drain pipes Austin Healey 29
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
drooartz Leaking 5-speed drain plug Spridgets 26
J TR2/3/3A Oil drain plug stuck Triumph 10
S TR2/3/3A Overdrive drain plugs leaks Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
Lin Rear differential drain plug leak Austin Healey 16
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
P Is there a seal between the drain channel and drain box? Austin Healey 8
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
JimLaney Drain holes relieve wing water retention? Spridgets 3
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
warwick-steve Magnetic Gearbox Drain Plug Austin Healey 28
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
C BN1 Overdrive drain plug question Austin Healey 0
Bob_Spidell Clip and ferrule for manifold drain pipes Austin Healey 4
N Drain plug?? Spridgets 17
M TR2/3/3A Air Vent Drain Hose Triumph 5
B BJ7 Drain Channel and Small Waist Trim piece question Austin Healey 13
Marla TR4/4A Oil Drain Plug Triumph 4
catfood BN1 Rear Axle drain plug. Austin Healey 7
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Healey Nut Another drain channel question . Austin Healey 21
Lutz Kramer Drain channel and trim rail Austin Healey 4
busybrit Removing the drain tube fron the rear mains cap. Austin Healey 4
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
