Picture Modification for Reassembly?
GerryL
I am currently taking pictures as I dissasemble my TR3. I would like to find a tutorial showing how I can modify the digital picture to contain arrows with associated comments. This would help me when I go to assemble the TR3 in the future.
Rhodyspit75
A lot depends on what you are using for software. Most I have seen have an edit feature. Once you open it you should be able to add text and draw in arrows. You can never have enough picture or notes. Things that look so familiar when you take them apart look really foreign a year later when you go to put them back together. I know I keep saying this but go to an electrical supply and pick up a book of wire markers they can be used on wires and terminals and just about anything else. I even took pictures of things like my solonoid with the markers on the wires.
ekamm
The wire markers/numbers worked great for me. Where ever I removed a connection I put a small piece of wire where it came from with a number and on the actual wire a corresponding number. It made re assembly of my dash pretty effortless.
bgbassplyr
I use MGI Photosuite. Its an old one but still works for me. Probably something better. Have you looked at Google's Picasa. Not sure if you can draw or write on the pix, though. Never tried to.
mrv8q
I find the factory Service Instruction Manual pretty handy in this regard, although I'm a big fan of digital pix as well...
M_Pied_Lourd
I have used Picnik in the past if I needed to lable and upload a photo.
https://www.picnik.com/
Cheers,
M. Pied Lourd
martx-5
When I pulled my car apart, it was before I had a digital camera. I would take things apart and put small associated pieces with the hardware in clear plastic bags, like freezer bags, with an index car stuffed in there with whatever info I felt was necessary. Since there is a lot of specialty hardware on these cars, that proved to be a godsend when putting things back together. I also had a log of the <span style="font-weight: bold">order</span> that I took things apart. I just followed it in reverse order putting back together. This way I wasn't sitting there looking at the wiper cable assembly after I had the whole dashboard in! Since I had parts spread out throughout the house and garage, I also had in the log the location of the parts. When I bought new parts, they went into the location log as well.
TR6oldtimer
Microsoft Paint is ok, and I use it at times, but I prefer to use Paint.net a freeware product in that it is much more robust.
https://www.getpaint.net/
Gordon_Dedrick
I had good luck with the "baggy" method also. I separated boxes of bags for dash, rear, engine comparment, etc, so I wasn't searching thru dozens of bags when it came to reassembly time. I found,however, that as the "freshening" process moved along I felt uncomfortable putting some of the old hardware back, so I put the new stuff in with the old. Ended up with a lot of baggies but a better looking car, I think.
Gordon
K TR2/3/3A Picture of the Zinc washer. Triumph 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
L Do you have a picture of these convertible top details? Spridgets 4
lram59 TR4/4A What's wrong with this picture? Triumph 4
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
steveg Picture needed - front turn light Austin Healey 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S TR4/4A Identify piece with a picture Triumph 7
steveg Great AH picture gallery Austin Healey 1
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
Marvin Gruber Need a picture please! Austin Healey 8
HealeyRick Sprite Factory Picture Spridgets 3
Marvin Gruber BJ8 brake booster picture Austin Healey 4
C Overdrive throttle switch rod connection picture Austin Healey 3
C Hub Puller...need picture Please! Austin Healey 4
S Your picture on road to Le Mans & Le Mans classic Spotted 8
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
Elva164 2014 VRG Turkey Bowl Video/Picture Thread! Racing 4
M General TR Restoration done, Picture time Triumph 33
P Bugeye front drum brake picture Spridgets 7
J Rocker valve assembly picture Austin Healey 6
Elva164 2014 PVGP Video/Picture Thread! Racing 32
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
thechileman TR4/4A Cool Picture.. Triumph 6
J Picture of temp gauge , Austin Mini British Motor Corp 2
D TR6 "big picture" engine diagram? Triumph 2
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
drooartz First picture of the family mini-fleet Spridgets 12
J TR2/3/3A Picture of painted substructure, finally! Triumph 8
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
M TR2/3/3A TR3 heater install picture needed Triumph 33
J Need a picture of how the transmission mounts to the frame. Triumph 3
John Turney Another picture question FORUM Navigation Questions 0
Tinkerman TR 3 Picture HELP Needed Triumph 5
CJD Picture of an early widescreen frame Triumph 28
P TR6 What happened to my TR6 picture? Triumph 1
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
HEALEYJAG cam specs for 100, 100-M.....bracket picture 100-M Austin Healey 8
dklawson Post-War Other Picture Needed - Herald and/or Vitesse Speedometer Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
M T-Series Looking for a picture of my MG-TF V8 form the sixt MG 1
B Second picture. I don't quite get this yet Triumph 1
S Old [for me] picture Spridgets 9
R posting a picture FORUM Navigation Questions 3
richberman picture of radiator side shields anyone? Austin Healey 10
N Picture series BJ8 distributor and carburettors Austin Healey 3
wangdango Bonnet striker plate detail picture/advice? Austin Healey 0
JPSmit Cool Picture thread Spridgets 57
H Picture of an original choke knob BJ7 anyone? Austin Healey 16
