Oil Leaks!
K
KSIS
So I decided to change all the oils in the Spit. Diff, tranny and motor. While I was under the car I decided to clean the old oil and dirt to make her look pretty. I found the lowest bolt on the timing chain cover loose. I went ahead and snugged it up to find it is stripped. I was able to tap and get a larger bolt in there and she snugs up.
When I fired her off and took her for a spin, I found I am leaking oil like a seive. Cleaning the grim off the engine opened up many weak spots. I have many of them resolved but the lower timing cover. I didnt think there was that much pressure behind the cover as there is the metal plate between two gaskets.
Wondering if I buggered the block and will I need to pull the engine or is there a different avenue to take.I am currently venting to the atsmosphere.
doughairfield
I was wrestling with a good number of leaks on my TR4 which finalized my decision to pull the motor, so I feel your pain. Did you put a little jointing compound on that bolt for the timing cover when you put it back in?
When I was researching ways to at detect the leaks in the hope that I would be able to fix them without pulling the motor, I saw a product you add to the oil that will make it glow under a black light, though I never tried it once I discovered the state of my valve guides. You could try cleaning up your engine, using that additive, and then seeing where the leaks are coming from. If it's all over like mine was, it will at least help you to know where to focus your efforts when putting your motor back together.
K
KSIS
I would love to pull the motor and do a gasket set. But I'm afraid of the domino effect. I'm not ready to do all that work.
Oil leaks:
pull engine/tranny/replace gaskets
paint /detail engine compartment
pull tub/paint frame
detail suspension/replace bushings
paint tub
doughairfield
oh yeah, serious domino effect. I wound up rebuilding my transmission too while I was at it. How I justified that, I still don't know.
If you do wind up using that additive, let me know, I'm sure I'll have an oil leak at some point.
PAUL161
This seems kinda odd. You Triumph guys have always told us MG guys that only MGs leak! Hmmm. I just had to say that. :devilgrin:
In all reality, I'm very familiar with the situation. PJ :jester:
K
KSIS
In all honesty it didnt leak (that much) before I started messing with it. I'm still kicking myself! I had my MG and it didnt leak. I have my fingers crossed for when I get home. I pulled the bolt out and covered it with RTV and stuck it back in. I will take it for a drive and see how it is.
I have one more can of brake cleaner and a shopping cart with gaskets saved readly to order.I may just pull the front off with the motor in the car...The radiator needs a paint job anyways.
Andrew Mace
I believe that lowest bolt on the timing cover actually bolts into the infamous front sealing block. On the other hand, if you've succeeded in retapping it and getting the bolt snugged down, odds are the timing cover gasket and possibly even the crank seal are bad. If that bolt has been loose, I'd almost be willing to bet on the timing cover gasket (just a paper gasket).
It's a bit of a pain to change, so it would be worth changing the seal when you change the gasket. And since you've already done one round of cleaning up, maybe you'll be able to resist the temptation to ultimately restore the entire car while you're changing out the seal and gasket. :wink:
doughairfield
I think there is an oil seal inside the timing cover where the dog bolt goes into the drive shaft. If you're taking the timing cover off, i'd replace that since it's cheap and easy. Also, and you probably know this, but that RTV takes 24 hours to fully cure, so i'd wait a day before putting it to the test.
JRC
Yikes. I'm leaving the gunk on mine for now. I want to drive it in the sun for a few months before starting the new round of fixes.
K
KSIS
I thought I was going to ba able to get one more season out of it before a tear down. I did let the RTV set for 24 hours. Drove it to pick up my son from track practice last night and then parked it in the garage. Crawled under it at ot looks like the thin paper gasket is shot and the crank seal is bad and slinging oil. So I pressed send on the shopping cart.
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
R TR2/3/3A Oil Leaks Triumph 24
Nelson Oil leaks again Spridgets 1
D Oil leaks Spridgets 22
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
M PCV and oil leaks Austin Healey 53
T external sealant for oil leaks Spridgets 6
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
M Can synthetic oil be cause of leaks? Spridgets 5
T Oil leaks under carb are - tappet inspection plate Spridgets 6
T sealing oil leaks in a horizontal joint Spridgets 6
rlich8 Introduction/Oil Leaks Triumph 14
RJS Crankcase Pressurization and Oil Leaks Triumph 11
T OIl Pan, no leaks Triumph 18
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
T oil leaks Triumph 32
M Oil leaks continued Austin Healey 16
M Oil Leaks Again Austin Healey 7
M Oil Leaks Austin Healey 17
E T-Series Oil pipe leaks on '50 TD-help! MG 7
M Common engine oil leaks Austin Healey 16
chrisc Wedge TR8 Oil Leaks Triumph 2
Atrus Let's talk oil leaks ;-] Spridgets 16
G 1967 Midget rear end leaks oil Spridgets 12
Woodie starter works,, but now oil LEAKS !! Spridgets 13
S British cars and oil leaks explained!!! MG 2
G Carb oil leaks out MG 8
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
